Suggestions...Please
I did a config check and I get this…
Platform error weather.darksky - Integration ‘darksky’ not found.
I have checked everywhere and I cannot find this anywhere… suggestions? It’s not in my config or anywhere in my lovelace.yaml, I checked all my automations…sensors etc…
I’m trying to figure out how to find the error so I can restart…
Thank you all!
It would be under weather:
For what it’s worth, Apple bought Darksky a few years ago and announced that their API would be shut down after a long grace period. That ended recently, so Darksky is no more…
Dark Sky has been removed with 2023.4.
Dark Sky has been removed. Apple acquired Dark Sky, and the API has now been shut down. (@gjohansson-ST - #90322)
Yeah I know Apple owns that now… I write modules for other programs so I’ve known it for a while and had to remove it all from my code there…
Still have to find in my HA instance where it is… like I said I’ve looked through everything…
Don’t have that in my config :wink:
So it’s not there
just search for darksky. There’s multiple ways to integrate it, all of them use that key.
EDIT: FOUND IT!!!
hahahahha
Thank you!
Yes I get that… I’ve been searching… every single file…integrations…not there.
ui-lovelace, config, etc… All taken out and not there and I keep getting that error…
Other suggestions on how to search everything without spending hours looking at every single file?
Thank you!
… Have you never used a find in files function? Notepad++, VSCode both have the ability to search for words in files.
Things like this take 1 minute to find tops. You have to use the correct tools.
Yes I have :slight_smile:
But I finally found it!!! Thank you!
Perfect use for the Linux grep command…
