michis0806
(Michael Schmid)
January 12, 2024, 10:15am
1
Hi there,
I want to measure the energy used by all lights in my home. I use a bunch of shelly devices that are all named with ‘light’ in the id.
{{ states
| selectattr('attributes.device_class', 'eq', 'energy')
| selectattr('entity_id', 'search', 'light')
| map(attribute='state')
| list
works as expected and lists the energy consumption of the devices. But it seems that the energy is presented as a string, not a float.
"0.221692",
"0.212433",
"0.0",
"0.156039",
"0.00156666666666667",
"0.0504",
"0.0",
"0.00666666666666667",
"5.84976666666667",
"0.399117",
"0.0457333333333333",
"0.00203333333333333",
"0.4977",
"0.6587",
"0.00596666666666667",
"0.0",
"0.0",
"0.0143",
"0.360583333333333"
so when I use
| sum
at the end, I get
TypeError: unsupported operand type(s) for +: 'int' and 'str'
Is there any way to convert the single values to floats?
Thanks!
Michael
danema
(David)
January 14, 2024, 7:12pm
2
Powercalc may work for you
I use it in a sankey chart to show energy/lights per room:
123
(Taras)
January 14, 2024, 7:47pm
3
{{ states
| map('float', 0)
| sum
You can restrict the list to light
entities by starting with states.light
as opposed to states
(which represents all entities in the system).
{{ states.light
| map('float', 0)
| sum
Your version of the template starts with all entities, narrows it down to the ones containing an energy
device class, then narrows it down again to the ones that contain the string light
anywhere in their entity_id. That means it will include light.kitchen
as well as switch.bedroom_light
(assuming both have the specified device class).
michis0806
(Michael Schmid)
January 15, 2024, 10:11pm
4
Perfect! That did it! Thank you.
The states.light will not work as there are some Shelly devices that I couldn’t get them to recognize themselves as light
Michael
