Thank you very much ‘Marius’, i’m sorry but the summary is not showing up anymore.
I have replaced the activity input_select, changed the png folder, changed the name of the automation to match with mine, deleted the light section for now, and replaced the group line.
Here is my updated code:
## https://github.com/maattdiy/home-assistant-config
## Screenshot: https://github.com/maattdiy/home-assistant-config/blob/master/screenshots/summary.png
## Script call: https://github.com/maattdiy/home-assistant-config/blob/master/config/packages/ha_triggers.yaml#L39
## Resources:
## https://home-assistant.io/components/python_script/
## https://home-assistant.io/docs/configuration/state_object/
debug = False
show_badges = True
show_card = True
group_count = 0
group_desc = ''
summary = ''
idx = 0
if debug:
event = data.get('event')
logger.error("\n\nSUMMARY: " + str(event))
## Group count (people and devices)
## Groups config: https://github.com/maattdiy/home-assistant-config/blob/master/config/groups.yaml#L267
# Entities summary by group name
groups = ['group.users_tracker'] # Groups need to have same member_count
groups_format = ['+{} at home: {}', '{} in use: {}', '!{} offline: {}'] # Message prefix
groups_filter = ['home', 'on|playing|home', 'off|idle|not_home'] # Filter to list
groups_badge = ['Home', 'In use', 'Status'] # Badge 'belt' (unit_of_measurement)
groups_badge_pic = ['', '', 'ok|bug|critical'] # Pictures: none, one, or a list of pictures (in this case the picture position will match the count)
groups_min_show = [0, 0, 0] # Mininum count to show
groups_desc = ['!Nobody home', '', '+System ok'] # Can set the default description, for use in case count = 0
groups_count = [0, 0, 0]
for group in groups:
group_count = 0
group_desc = ''
for entity_id in hass.states.get(group).attributes['entity_id']:
state = hass.states.get(entity_id)
filter = groups_filter[idx]
if (state.state in filter.split('|') or debug):
dt = state.last_changed
dt = dt + datetime.timedelta(hours=+1)
time = '%02d:%02d' % (dt.hour, dt.minute)
# If state changed in the past days show the date too
if dt.date() < datetime.datetime.now().date():
time = '{} {}'.format('%02d/%02d' % (dt.day, dt.month), time)
group_count = group_count + 1
group_desc = '{} {} ({}), '.format(group_desc, state.name, time)
# Final format for this group
if (group_count >= groups_min_show[idx]):
if (group_count == 0):
group_desc = groups_desc[idx]
else:
group_desc = groups_format[idx].format(group_count, group_desc[:-2])
groups_desc[idx] = group_desc
groups_count[idx] = group_count
idx = idx + 1
## Badges updates
idx = 0
order = 2
if show_badges:
for badge in groups_badge:
if (badge != ''):
entity_id = 'sensor.{}_badge'.format(badge.replace(' ', '').lower());
hidden = False if (groups_count[idx] >= groups_min_show[idx] or debug) else True
fname = groups_desc[idx] if debug else ' '
picture = groups_badge_pic[idx].replace(' ', '').lower()
# Check for picture X index/count
if (picture != ''):
list = picture.split('|')
if (len(list) in [1, groups_count[idx]]):
picture = list[len(list)-1]
else:
picture = list[groups_count[idx]]
if (picture != ''):
picture = '/local/badges/{}.png'.format(picture)
hass.states.set(entity_id, groups_count[idx], {
'friendly_name': fname,
'unit_of_measurement': badge,
'entity_picture': picture,
'hidden': hidden,
'order': order
order = order + 1
idx = idx + 1
## Alarm clock
## Package: https://github.com/maattdiy/home-assistant-config/blob/master/config/packages/alarmclock.yaml
alarms_prefix = ['alarmclock_wd', 'alarmclock_we']
alarms_wfilter = ['1|2|3|4|5', '6|7']
alarms_desc = ''
idx = 0
for entity_id in alarms_prefix:
state = hass.states.get('input_boolean.{}_enabled'.format(entity_id))
if (not state is None):
if (state.state == 'on'):
# Show the alarm for the next day
if (str(datetime.datetime.now().isoweekday()) in alarms_wfilter[idx].split('|')):
state = hass.states.get('sensor.{}_time_template'.format(entity_id))
alarms_desc = '{}{}, '.format(alarms_desc, state.state)
idx = idx + 1
if (alarms_desc == ''):
alarms_desc = '!Alarm clock is disabled'
else:
alarms_desc = 'Alarm clock set at ' + alarms_desc[:-2]
## Mode:
## General package: https://github.com/maattdiy/home-assistant-config/blob/master/config/packages/profiles.yaml
## Developer package: https://github.com/maattdiy/home-assistant-config/blob/master/config/packages/developer.yaml
## Badges images: https://github.com/maattdiy/home-assistant-config/tree/master/www/profiles
mode_desc = ''
state = hass.states.get('input_select.ha_mode')
# Get info
#dt = datetime.datetime.now()
#time = "%02d:%02d" % (dt.hour, dt.minute)
hidden = False #if (state.state != 'Normal') else True
if (state.state != 'Unknown'):
dt = hass.states.get('automation.mode_selection').attributes.get('last_triggered')
if (not dt is None):
time = "%02d:%02d" % (dt.hour+1, dt.minute)
hass.states.set('sensor.mode_badge',state.state, {
'entity_picture': '/local/profiles/{''}.png'.format(state.state.replace(' ','').lower()),
'friendly_name': time, #was: ''
'unit_of_measurement': 'Mode',
'hidden': hidden,
'order': order
if not hidden:
mode_desc = '{}*{} mode selected at: {}\n'.format(summary, state.state, time)
## Activity:
activity_desc = ''
## Get activity description
state = hass.states.get('input_select.harmony_hub')
state_value = hass.states.get('input_select.harmony_hub').state
#time = '?'
# Get info
#dt = state.attributes.get('last_triggered')
#time = '%02d:%02d' % (dt.hour, dt.minute)
if not state is None:
if state.state != 'Unknown':
dt = hass.states.get('automation.activity_change').attributes.get('last_triggered')
if not dt is None:
if not hidden:
activity_desc = '{}*{} activity selected at: {}\n'.format(summary, state.state, time)
hass.states.set('sensor.activity_badge', state_value, {
'friendly_name': time, #state_value,
'entity_picture': '/local/activities/{' '}.png'.format(state_value.replace(' ','').lower()),
'unit_of_measurement': 'Act'
## Summary update
## Custom card: https://github.com/maattdiy/home-assistant-config/blob/master/www/custom_ui/state-card-value_only.html
for group_desc in groups_desc:
if group_desc != '' and not group_desc.endswith(': '):
summary = '{}{}\n'.format(summary, group_desc)
# original
# summary = '{}\n{}\n{}'.format(summary, alarms_desc, mode_desc)
## Add to final summary
summary = '{}\n{}\n{}\n{}\n{}'.format(summary, alarms_desc, activity_desc, mode_desc, lights_desc)
if show_card:
hass.states.set('sensor.summary', '', {
'custom_ui_state_card': 'state-card-value_only',
'text': summary
Thanks for your time.
