That will trigger:
- When Home Assistant starts, if the sun elevation is below 36 degrees at that time.
- When the sun elevation changes from 36 degrees or above to below 36 degrees.
That will trigger:
so it will work
I don’t think it will work as you want. Assume no home assistant restarts.
This light will turn on for 3 minutes and switch off (but only when the sun goes down during the summer).
This event will only occur once per day. Do you want something else to trigger the light? Like motion?
nop only the sun elevation cause it gets darker in that room past that sun elevation numbers Ive checked it several times and I think this is the code
