The problem is, as soon as it hits midnight, it no longer works (triggers the light on), any idea why that is? Should it not continue to turn on my light until sunrise happens?
alias: Lights - Turn on kitchen lights when there is movement
- entity_id: binary_sensor.motion_sensor_motion
platform: state
to: 'on'
condition:
- after: sunset
after_offset: '-30'
condition: sun
- entity_id: light.bottom
service: homeassistant.turn_on
what do you think? Add another condition underneath that says before sunrise to make it work after midnight?
This condition allows 30 mins before sunset to midnight
(why not use the before_offset: ?)
So yes add another condition for before sunrise:
But these conditions will need to be 'orâed rather than the standard âandâ
Consult the docs for that
30 Before sunset doesnât work (the lights donât come on) makes no sense should be the same as -30 after?
Also tried the OR and again same thing, nothing turns on on motion:
I dont play with AE so my opinion means nothing
They are still finessing the AE and it will support more features soon, until then âhand craftedâ is your only option.
Your automation should look like this : -
#### or condition
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition: sun
after: sunset
before_offset: '30'
- condition: sun
before: sunrise
after_offset: '30'
You will probably have to cut and paste this over your existing auotmation, DO NOT use the AE for this.
But by all means look at it in the AE afterwards just to see what it makes of it
Thanks for that, I think I might have another solution if it works, based on the state:
- condition: state
entity_id: sun.sun
state: below_horizon
It is not as configurable since I canât add the offsets but it might do the trick.
Will try your suggestion as well since I think if I wait for the below_horizon state, it might already be dark when that happens
This says ONLY if sun is 4.2° below the horizon, tweak if you are unhappy with the light level that gives (the lower angle. the less times the bulb switches on and saves both bulb life and power cost, double win) Angle is a much better offset than time as the light is more consistent.
Ideally I shouldnât need the sun at all but the lux value of the aqara sensor is not enough as it is as low as full darkness even during the day (which sort of makes it useless for the main reason I have bought it)
#### or condition
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition: sun
after: sunset
after_offset: '-30'
- condition: sun
before: sunrise
before_offset: '30'
Many have been confused by this. after_offset is the offset that goes with the after option, and before_offset is the offset that goes with the before option. Positive offsets mean after the after/before event, and negative offsets mean beforethe after/before` events.
I should also add, an offset of 30 means 30 seconds, not 30 minutes, which is what I suspect you wanted.
(As expressed in YAML), the after_offset and before_offset parameters, like most âamount of timeâ, or âtime periodâ, options can accept a value in any one of these formats:
SECONDS
'HH:MM'
'HH:MM:SS'
or a âdictionaryâ like the following, where you can supply one or more of the key/value pairs:
days: DAYS
hours: HOURS
minutes: MINUTES
seconds: SECONDS
milliseconds: MILLISECONDS
So for an offset of -30 minutes, you could express that in any of these ways:
The docs (which I consulted for this as I only ever use elevation) was less than clear on the before/after syntax)
I have to admit on the time thing I just went with the OPâs format and didnât check, my apologies.
Yep, as I said, âMany have been confused by this.â I suppose I should spend some time and try to make the wording better. Iâm also thinking about changing the sun conditions so they can span midnight, just like the time condition allows. I think that would make it much easier for most people to use (rather than have to write the complex âorâ condition, which is also confusing to most, at least at first.) Be clear, though, I didnât write the sun condition or its documentation in the first place. lol
Ahhh but you are forgetting the old addage that itâs the responsibility of whoever looked at it last.
But I quite like the sun component as it is, Iâm aware of your enhanced and sun2 but they donât give me much, it just makes it easier for some to write code without considering the consequences (not always a good thing) And I must stress I mean no disrespect. And that is also not to say I wonât find a use for it tomorrow.
Given that there are so many inconsistent approaches within HA (you can use a template icon for this but not for that, customisation for this but not for that, icon colour for this but not for that, you can use before for this but must after for that AND the sign of the number inverts that anyway but Iâm not going to tell you that.
The list goes on
So Iâd rather they fix the inconsistencies, write a general spec all entities must comply with and then start making it happen.
But Iâm not a dev
