Sun.azimuth state as trigger for automation
I have an automation that closes my roller shades when the sun.azimuth is greater than 180, with an additional condition based on a lux sensor value (i.e. is it really bright enough outside to bother closing the shades?).
This automation works great. However, I was expecting it to re-trigger every time the sun.azimuth state changed. With the idea that it might be cloudy when the sun is at 180 but, if the sun comes out later in the afternoon (azimuth is now at 193 or something) it should lower the shades. But it seems to only trigger once, when the azimuth goes above 180.
I have looked at other similar automations and it seems like mine should work as I am expecting it to. But I am now wondering if there is something unique about state changes for sun.azimuth.
Relevant config:
alias: Blinds Down If Afternoon Sun
description: ""
  - platform: numeric_state
    entity_id:
      - sun.sun
    attribute: azimuth
    above: 180
condition:
  - condition: numeric_state
    entity_id: sensor.multisensor_illuminance
    above: 250
    entity_id: sun.sun
    attribute: elevation
    above: 1
  - device_id: e1e7260d02c0a71343c2d5769c8f8180
    domain: cover
    entity_id: cover.family_room_shades
    type: close
  - device_id: fd1f05469bc81d0be26808c400cd4335
    domain: cover
    entity_id: cover.dining_bay_shades
    type: close
  - device_id: 260854b654e16207a56eb57c52987542
    domain: cover
    entity_id: cover.kitchen_west_shade
    type: close
mode: single
The numeric state trigger occurs when the azimuth goes above 180. It has to fall below 180 then go above to trigger again.
You can do this:
description: ""
  - platform: state
    entity_id:
      - sun.sun
    attribute: azimuth
    not_to:
      - unavailable
      - unknown
condition:
    entity_id: sun.sun
    attribute: azimuth
    above: 180
    above: 250
    entity_id: sun.sun
    above: 1
This will trigger whenever the azimuth changes then check if it is above 180 in the conditions.
Ah, ok. Makes sense. I’ll give that a try and update the thread with the results. Thank you!!
You could always turn the logic on its head. Trigger on illuminance above 250, then check the azimuth is between the values you want. That way you won’t be triggering hundreds of times a day as azimuth changes all the time…
