Sun Component: translating error, how to correct directly in my Home Assistant?
Hello everybody,
I am happy to take part to the Home Assistant family :slight_smile:
I am learning in managing Home Assistant, and facing all little problems; but for this one, is a little too hard.
The sun component has some bad translations; in particular, in the attached picture, the lines with the bad translation are signed with a red arrow.
In particular, if I am not wrong, the lines are referred about:
  • next sunrise;
  • next sunset;
  • sun elevation.
If so, I want to try to change the translation directly in the Home Assistant “settings files” (maybe… code?) for a fast correction of the translation.
What can I do to do it?
Thanks to everyone for your time and help.
Join the team and help fix it:
https://developers.home-assistant.io/docs/en/internationalization_translation.html
@tom_l, I gave my contribution (I hope correctly) to the translation, but there are a few things about it that for me are not so clear:
  1. How dows it work about the translation? Is about a votation where the most choose option will be insert in the official translation?
  2. How much time does it take for a change in the translation project to be official?
Those two questions made me think about modify directly my Home Assistant translation file, to have a quick solution to my problem.
