For some reason, although my time zone is set correctly, the sun device is setting the sunrise/sunset about eight hours off from my time zone. There seems to be nothing obvious in my config file that would be overriding this. What could be the culprit?
When I click on the “edit location” button, I am shown a map that indicates my home is in the middle of Amsterdam (second image below.) When I click on the edit pencil icon, I’m brought back to the page in the first image below.
So, your location is not set correctly, and that’s why the calculation of sun position can’t come with correct results.
You need to find your location on that map and set it as home zone.
Sorry I didn’t realize I didn’t make it clear that I don’t live in the middle of Amsterdam. The problem is that when I move the map to where I really am (and I’m confused why I have to do so,) it doesn’t persist. And besides, the CDT time zone is thousands of miles off from Amsterdam and the Sun seems to ignore the time zone.
FYI, you can go to Settings → System → General → Edit location to get the map view of your location, then drag the Home icon to the correct location (as opposed to simply moving the map). IDK if the OP tried that, but I had the same problem and that’s how I was able to solve it.
Note that you have to zoom out quite a bit in order to drag it a long distance, then zoom back in as you get it closer to your home area. It would be nice to have address lookup built in to make this easier.
