I am trying to create a template sensor which calculates the percent of daylight that has elapsed.
i have some coding skills but this seems to be a bit out of my league.
I’m trying to create a sun elevation card (with picture elements).
To account for the daily change of the amount of daytime i thought a percentage would work to define picture elements for the different sun elevations
I found some code snippets here and there and put them together in the template editor… but it doesnt seem to work…
sensors:
day_percentage:
friendly_name: "Percentage of day"
value_template: >-
{% set total_daylight = states('sensor.daylight_hours') %}
{% set daylight_remaining = as_timestamp(state_attr('sun.sun','next_setting') | float - now().timestamp() | int ) | timestamp_custom('%H:%M', false) %}
{{ (daylight_remaining/total_daylight)*100 }}
You were close, but brackets in the wrong place and more type conversions than you needed. Try this line:
{% set daylight_remaining = (state_attr('sun.sun','next_setting')|as_timestamp - now()|as_timestamp)|timestamp_custom('%H:%M', false) %}
That’s a string, though (like you asked for with timestamp_custom) and your final line then makes no sense. What does {{ states('sensor.daylight_hours') }} return?
It returns the total amount of daylight time.
I’ll give it a try this afternoon and get back to you!
The final line is where the template editor started giving me the error: TypeError: unsupported operand type(s) for /: ‘str’ and ‘str’
I’m trying to make a percentage… and that is how far I got with the calculations
I’ve used the final line before in a different sensor that works…
It might be that i cant do these calculations with time?
example of the working sensor:
sensors:
corona_change:
friendly_name: "Inzidenz Change"
value_template: >-
{% set n = states('sensor.sk_koln_newcases') | float %}
{% set r = states('sensor.sk_koln_newrecovered') | float %}
{% set d = states('sensor.sk_koln_newdeaths') | float %}
{{ (n - (r+d)) | round(0) }}
Not with strings like “03:34”, no. You should read and get familiar with this:
Sensors’ states are always strings, even if they look like numbers. You need to turn them into numbers using |int or |float before doing any arithmetic on them.
You’ll probably find it easier to convert all the times you’re working with into UNIX timestamps (seconds since 1970; all documented at the link above), so you end up with seconds of daylight and seconds until sunset.
