stephang
(Stephan Gumpert)
September 23, 2022, 10:23am
1
The SUN integration has a state below_horizon and above_horizon could this technically mean night and day? as in below_horizon is considered for a better term night? (After sunset and before sunrise)???
Trying to create a template for the night as I have much automations that only fires at night.
Thoughts, suggestions or help? Thanks
Blacky
September 23, 2022, 10:47am
2
I am happy with state below_horizon and above_horizon because it is a nice way to run your automations. Example 1hr after below_horizon is dark (night). It is a nice consistent point that you can always rely on.
bouwew
(Bouwe)
September 23, 2022, 10:54am
3
I have this in my configuration.yaml:
sensors:
period_of_day:
friendly_name: "period of the day"
value_template: >-
{% if (as_timestamp(states.sun.sun.attributes.next_dusk) - as_timestamp(states.sun.sun.attributes.next_setting)) < 0 %}
dusk
{% elif (as_timestamp(states.sun.sun.attributes.next_rising) - as_timestamp(states.sun.sun.attributes.next_dawn)) < 0 %}
dawn
{% elif (states.sun.sun.attributes.elevation) < -4 %}
night
{% else %}
day
{% endif %}
icon_template: >-
mdi:weather-sunset-down
mdi:weather-sunset-up
mdi:weather-night
{% else %}
mdi:weather-sunny
{% endif %}
Found it a long time ago on this community
The format should be updated, I’ll look at this later. No hurry though, the above format still works.
tom_l
September 23, 2022, 12:17pm
4
Yes that is exactly what it means.
For example to only run your automation at night include the following condition:
condition:
condition: state
entity_id: sun.sun
state: "below_horizon"
stephang
(Stephan Gumpert)
October 2, 2022, 1:25am
5
When I test the sensor it seams to work, however in the logs I get som errors for the code in the ICON_TEMPLATE.
If I test the code separately in the DEV TOOLS → TEMPLATE, it appears to be ok.
Any ideas?
Is this a bug that should be reported else where?
2022-10-02 11:00:48.300 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'None' has no attribute 'attributes' when rendering '{% if (as_timestamp(states.sun.sun.attributes.next_dusk) - as_timestamp(states.sun.sun.attributes.next_setting)) < 0 %}
mdi:weather-night
{% else %}
mdi:weather-sunny
{% endif %}'
bouwew
(Bouwe)
October 3, 2022, 9:47am
6
I think this has to do with the fact that the method to create a template-sensor is outdated.
See Template - Home Assistant for the new format.
bouwew
(Bouwe)
November 28, 2022, 7:01pm
7
Updated using the template
format:
template:
- sensor:
- name: "Period of the day"
state: >
{% if (as_timestamp(state_attr('sun.sun', 'next_dusk')) - as_timestamp(state_attr('sun.sun', 'next_setting'))) < 0 %}
dusk
{% elif (as_timestamp(state_attr('sun.sun', 'next_rising')) - as_timestamp(state_attr('sun.sun', 'next_dawn'))) < 0 %}
dawn
{% elif (state_attr('sun.sun', 'elevation')) < -4 %}
night
{% else %}
day
{% endif %}
icon: >
mdi:weather-night
{% else %}
mdi:weather-sunny
{% endif %}
