I recently switched my HA server from a docker install (Umbrel node) to a VirtualBox VM (an old MacMini). A few odd things are happening but the most frustrating is sun.sun elevation refuses to update unless I manually reload the entity from the Settings > Devices & Services page.
Sun elevation was working as expected in my old docker instance (e.g: updating value every few minutes around dusk/dawn etc). but elevation is not updating at all, any time of day, in the new VM setup.
The only major change was going from version 2022.11 to 2023.3 – the VM install was fresh, and installed from a backup of the docker.
Any suggestions were to resolve this? Other information from the Sun is updating (Next Setting, Next Rising etc.) but not elevation! Thanks in advance.
Hi – thanks for the suggestion – I tried all the time zone / location based stuff, plus numerous restarts / VM reboots and yaml cleanses etc. No impact sadly.
Meanwhile … I think I got sun elevation working again? I’ll report back in a day or so if true, but I deleted the HA database file, did a complete VM reboot and so far it’s updating values as I would expect. Via ssh / CLI:
It might be of interest for you to review the following topic which takes a deep-dive into how that parameter’s value may affect the clock. I think if you start from this post and continue from there it will reveal that the user’s problem with clock-drift (VM on an iMac) was fixed by setting Paravirtualization to “Legacy”.
If “None” works for you then all’s well but if you start noticing clock-drift then keep that topic’s discussion in mind.
Maybe an unrelated cause, but the Title of this thread is absolutely 100% what was my problem.
This afternoon we experienced one of the all too frequent power cuts. When power was restored a few hours later, the HA server started up again and HA was accessible and seemed to be working. But…
Some lights did not switch on when they should and on checking for the reason (presumably something to do with the harsh power off and restart) I noticed that almost half an hour after the sun had actually set, sun.sun’s elevation attribute was stuck at 7.66°. I watched it for a bit, but it really was stuck at that value.
As it happened, there was a core update waiting to be installed, so I did that and after the HA restart, the elevation was correct and updating as it should.
So no actual current problem, but seems to me that an attribute like that shouldn’t simply get stuck, even after the forced hard restart.
