I recently switched my HA server from a docker install (Umbrel node) to a VirtualBox VM (an old MacMini). A few odd things are happening but the most frustrating is sun.sun elevation refuses to update unless I manually reload the entity from the Settings > Devices & Services page.
Sun elevation was working as expected in my old docker instance (e.g: updating value every few minutes around dusk/dawn etc). but elevation is not updating at all, any time of day, in the new VM setup.
The only major change was going from version 2022.11 to 2023.3 – the VM install was fresh, and installed from a backup of the docker.
Any suggestions were to resolve this? Other information from the Sun is updating (Next Setting, Next Rising etc.) but not elevation! Thanks in advance.
Hi – thanks for the suggestion – I tried all the time zone / location based stuff, plus numerous restarts / VM reboots and yaml cleanses etc. No impact sadly.
Meanwhile … I think I got sun elevation working again? I’ll report back in a day or so if true, but I deleted the HA database file, did a complete VM reboot and so far it’s updating values as I would expect. Via ssh / CLI:
It might be of interest for you to review the following topic which takes a deep-dive into how that parameter’s value may affect the clock. I think if you start from this post and continue from there it will reveal that the user’s problem with clock-drift (VM on an iMac) was fixed by setting Paravirtualization to “Legacy”.
If “None” works for you then all’s well but if you start noticing clock-drift then keep that topic’s discussion in mind.
