Please remove. No answers and I have chose another distribution entirely.
Maybe the documentation helps:
You can see that the times shown in the /dev-state are in UTC.
When you display the values in your GUI, however, they are automatically converted to your local timezone by using the entries in your configuration file. Same is valid for using these times in automations, conditions, etc.
Use this set up as a template sensor:
sensors:
# Sunset & Sunrise
next_sunrise:
friendly_name: Sunrise
value_template: '{{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom("%H:%M") }}'
next_sunset:
friendly_name: Sunset
value_template: '{{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom("%H:%M") }}'
Try this as an entities-card in the Lovelace frontend and you’ll see what I mean:
# Sunset/Sunrise Info
- type: entities
title: Sunset & -rise
entities:
- entity: sensor.next_sunrise
name: "Next Sunrise:"
icon: mdi:weather-sunset-up
- entity: sensor.next_sunset
icon: mdi:weather-sunset-down
Or just paste this into the (currently already filled /dev-template
Thanks for your answer! I will try this out, hoping for a better result
Cheers
Next time you have a question like this, just share the code that doesn’t work for you.
It’s much easier to provide an answer if people can understand the problem in more detail.
Hi!
Where do I put the 2 codes? in which files?
