Sundown Theme: no background image
Installation
Add the following code to your configuration.yaml file (reboot required).
frontend: … # your configuration. themes: !include_dir_merge_named themes … # your configuration.
Add the following line to your lovelace-ui.yaml or use the RAW editor:
background: var(--background-image)
I’ve added this here:
  - path: adaptive-lighting
    title: Adaptive Lighting
    icon: 'hass:theme-light-dark'
    theme: sundown
    badges:
      - entity: input_boolean.sleep_mode
    cards:
      - type: entities
His image:
My image:
What am I not doing right???
I have added my
line directly below the first Title line and above the Views line.
HTH
That’s a no go!
I had the same results as you when using it as a page theme, but it worked correctly when set as my profile theme.
Thank god you’re here to explain where “background: var(–background-image)” goes
Big help!
Ever found out about this? Have the same issue.
No but over the years it fixed itself. I do not have background: var(--background-image) anywhere in my raw config yet when I select theme sundown it now has the desired background image.
