hi,
I am using Home Assistant (docker version) with the Sungrow Integration of mkaiser via ModBus: https://github.com/mkaiser/Sun…ter-Modbus-Home-Assistant
This has been working for quite a while (energy dashboard, entities… all fine). Since “some” change I did (I am not sure what might have been the trigger), I have the following status:
The Modbus entities are shown as “unavailable” .
I can reach the inverter under the previously configured fixed IP via “ping”. An “nmap” portscan shows the open Modbus port 502.
The IP that I use for “ping” is the same that is configured in “secrets.yaml” under sungrow_modbus_host_ip
The problem seems to be on modbus level or in the modbus integration in Home Assistant, not on IP level.
configuration.yaml contains:
homeassistant:
packages: !include_dir_named integrations
The “integrations” folder contains the file modbus_sungrow.yaml.
How can I check that Home Assistant is trying a communication via Modbus?
Thanks.
