Sunmaster XS3200 & Elfin ew11 Serial (RS-485) to Wi-Fi
Hey All,
Very new here (although I have been tinkering in the background for nearly a year now :smiley:)
So please do go easy on me, I have some technical knowledge and have been in IT for years, but mostly on the delivery side, so everything I know in regards to this is really self taught, so if I have forgotten to click a switch, go easy eh :wink:
So we have a Sunmaster XS3200 Solar inverter, and I would like to pull the live data from it into HA without the need for the very costly MasterVolt ā€œMasterBussā€ stuff.
Sooooā€¦ after some research I found this nice little gem by kloknibor which although he mentions has only been tested on the XS2000, as they are the same model range I would suspect they are close enough.
So I then checked my Manual for the panels, and it uses RS-485 Serial (apparently) so I plumped for the Elfin ew11 which I have seen others here use, but with different solar inverter or batteries!
So I plugged up the unit the other night, and waited patiently (no power is supplied to the unit when the DC from the solar is not running) the following morning the unit had life as the inverter powered up, I got this onto the Wi-fi without too much bother and I can see it on the networkā€¦ itā€™s lights indicate it is receiving data from the inverter (it pulses every few seconds).
I then set-up the integration as per instructions, and I see the sensors, however HA isnā€™t getting any dataā€¦ now to test that HA can ā€œseeā€ the device I changed the TCP Port in my config to something random, and I had loads of errors after a reboot, as HA couldnā€™t connect to the device, change it back and the logs are quiet but still no data.
Snip from my Config Fileā€¦ (and all files needed are in the correct locations, and you can generate errors by commenting out key parts, so itā€™s reading it)
   - platform: MasterVoltXS
     TCP_PORT: 8899
     TCP_IP: 192.168.1.136
     RECONNECT_INTERVAL: 10
Here is a screen shot of the Serial Port Settings, I have tried fiddling with these, but nothing seems to have any impact.
(Note Modbus Protocol, as this I believe is what the inverter uses, BUT I donā€™t know for sure, and I have tried with ā€œModbusā€, ā€œNoneā€, and ā€œFrameā€)
And the TCP Settings on the device:
As I am new I canā€™t add another screenshot so they areā€¦
Protocal: TCP Server
Local Port: 8899
Buffer Size: 512
Keep Alive: 60
Timeout: 0
Max Accept: 3
Security: Disable
Route: Uart
So essentially I am now stuck and have exceeded my knowledge, the only other thing that has crossed my mind is the cable, I am using a short Cat5 cable, it seems from all the docs I can find that these RS-485 cables are normally straight through (Pin 1 > Pin 1 etc) and the fact I have power and some data making a light blink, I would imagine itā€™s correct, but I did consider making up a short lead with the relevant data pins crossed over, but I doubt that would make any difference? And I am not sure where my RJ-45ā€™s are :smiley:
I already use Shelly Energy monitoring on my three phase supply (they canā€™t do smart meters for us, THANK GOD) but rather than get another clamp for the Solar, I would rather be able to read the data off the device (which at the moment is impossible without climbing into the loft and jabbing itā€™s buttons).
Is there anyway I can ā€œredā€ the raw data from the device myself to just confirm it is there?
Any help, suggestions or information would be much appreciated :slight_smile:
JC.
Bump!! Wondering if anyone can help? :smiley:
