Sunny Tripower 5000TL-20 - into HA
I have a Sunny Tripower 5000TL-20 (yep since 2014)
I don’t seem to find a way to get the data into HA… The SMA Integration always returns “couldn’ connect”… (whatever boxes I select or not)
→ the IP address is correct
→ I do know the PV Password…
I dom get results in the Web through Sunny Portal… so the Inverter IS transmitting and the data is real… but how can I have it downloaded to HA?
Would appreciate help…
thanks!
did you install the SMA Solar integration in HA with the correct values?
maybe you can find more info here:
