Sunricher SG2858A blueprint
This blueprint is for controlling a light with the Sunricher SG2858A remote. The following is supported:
  • set color
  • set light temp
  • on / off
  • dim up/down (short press = step, long press = move)
  • buttons S1 to S5 can either execute custom scripts, or activate a scene (configurable)
  • all three endpoints (buttons 1, 2, 3) of the remote are supported, you have to instantiate this blueprint once for each endpoint
The only thing that is not working currently is the Home(6) button, which does not trigger a zha event currently. Needs to investigate on this (probably needs a quirk).
blueprint:
  name: Handle sunricher sg2858a events
  description: >
    Runs the light commands given the received events.
    The device supports 3 groups, and sends commands for all the selected
    groups.
    The following commands are supported for each endpoint:
    * recall (scene mode), 1 to 5
    * dim (step) down / up
    * dim up/down with stop
    * move to color
    * move to temp
    * "on" and "off" (separate commands)
  domain: automation
  input:
    remote:
      description: The remote device to use for the automation
      selector:
        device:
          entity:
            - integration: zha
          filter:
            - manufacturer: Sunricher
              integration: zha
              model: ZG2858A
#      default:
#        device_id: 17cd50f04cd5e8c747b276faf4b59eac
    target_light:
      name: Light to control
      description: The light to control with the remote
      default: {}
      selector:
          entity:
            - domain: light
    source_endpoint:
      name: Group (1, 2 or 3)
      description: The remote group this script uses (1, 2, 3 on the remote)
      default: 1
      selector:
        number:
          min: 1
          max: 3
          step: 1
    scene_recall_script_1:
      name: Script or scene to call for scene recall 1
      default: null
      selector:
        entity:
          filter:
            domain:
              - script
              - scene
    scene_recall_script_2:
      name: Script or scene to call for scene recall 2
      default: null
      selector:
        entity:
          filter:
            domain:
              - script
              - scene
    scene_recall_script_3:
      name: Script or scene to call for scene recall 3
      default: null
      selector:
        entity:
          filter:
            domain:
              - script
              - scene
    scene_recall_script_4:
      name: Script or scene to call for scene recall 4
      default: null
      selector:
        entity:
          filter:
            domain:
              - script
              - scene
    scene_recall_script_5:
      name: Script or scene to call for scene recall 5
      default: null
      selector:
        entity:
          filter:
            domain:
              - script
              - scene
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input remote
      endpoint_id: !input source_endpoint
      command: "off"
      args: []
      params: {}
  - platform: event
    event_data:
      command: "on"
      args: []
      params: {}
  - platform: event
    event_data:
      command: "step_with_on_off"
      args: [0, 32, 0]
      params:
        step_mode: 0
        step_size: 32
        transition_time: 0
  - platform: event
    event_data:
      args: [1, 32, 0]
      params:
        step_mode: 1
        step_size: 32
        transition_time: 0
  - platform: event
    event_data:
      command: "move_to_color"
#       params:
#         color_x: 15859
#         color_y: 33357
#         transition_time: 0
#         options_mask: 0
#         options_override: 0
  - platform: event
    event_data:
      command: "move_to_color_temp"
#      params:
#        color_temp_mireds: 440
#        options_mask: 0
  - platform: event
    event_data:
      command: "move_with_on_off"
      params:
        move_mode: 0 #  1 <-- down, 0 for up
  - platform: event
    event_data:
      params:
        move_mode: 1 #  1 <-- down, 0 for up
  - platform: event
    event_data:
      command: "stop_with_on_off"
  - platform: event
    event_data:
      command: "recall"
#     params:
#       group_id: 0
#       scene_id: 5
variables:
  scene_recall_script_1_v: !input scene_recall_script_1
  scene_recall_script_2_v: !input scene_recall_script_2
  scene_recall_script_3_v: !input scene_recall_script_3
  scene_recall_script_4_v: !input scene_recall_script_4
  scene_recall_script_5_v: !input scene_recall_script_5
mode: restart # restart is very important, the move with stop handling
              # relies on this
  - choose:
    - conditions:
      - condition: trigger
      sequence:
        - service: light.turn_on
          target: !input target_light
            xy_color:
              - '{{ trigger.event.data.params.color_x| int / 65535 }}'
              - '{{ trigger.event.data.params.color_y | int / 65535 }}'
    - conditions:
      sequence:
            brightness_step_pct: 8
    - conditions:
      sequence:
            brightness_step_pct: -8
    - conditions:
      sequence:
    - conditions:
      sequence:
        - service: light.turn_off
    - conditions:
      sequence:
            color_temp: '{{ (trigger.event.data.params.color_temp_mireds |int) + ((trigger.event.data.params.color_temp_mireds | int)- 314.5) / 5 }}'
    - conditions:
      sequence:
        - repeat: # repeat inconditionnally. Script is interrupted by another instance by stop event
            count: 13
            sequence:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 0
                  milliseconds: 300
    - conditions:
      sequence:
        - repeat:
            count: 13
            sequence:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 0
                  milliseconds: 300
# scene recall
    - conditions:
      - '{{ trigger.event.data.params.scene_id == 1 }}'
      sequence:
          - if:
            - '{{ scene_recall_script_1_v != None }}'
            then:
              - service: homeassistant.turn_on
                  entity_id: '{{ scene_recall_script_1_v }}'
    - conditions:
      - '{{ trigger.event.data.params.scene_id == 2 }}'
      sequence:
          - if:
            - '{{ scene_recall_script_2_v != None }}'
            then:
                  entity_id: '{{ scene_recall_script_2_v }}'
    - conditions:
      - '{{ trigger.event.data.params.scene_id == 3 }}'
      sequence:
          - if:
            - '{{ scene_recall_script_3_v != None }}'
            then:
                  entity_id: '{{ scene_recall_script_3_v }}'
    - conditions:
      - '{{ trigger.event.data.params.scene_id == 4 }}'
      sequence:
          - if:
            - '{{ scene_recall_script_4_v != None }}'
            then:
                  entity_id: '{{ scene_recall_script_4_v }}'
    - conditions:
      - '{{ trigger.event.data.params.scene_id == 5 }}'
      sequence:
          - if:
            - '{{ scene_recall_script_5_v != None }}'
            then:
                  entity_id: '{{ scene_recall_script_5_v }}'
Hope this will be useful for others.
