Sunricher SR-ZG9100A-S firmware
I recently bought a SR-ZG9100A-S. The local vendor here did not make a distinction between different configurations of the device, but the manual states:
Supported external switch types (should be configured by factory setting):
  1. Push switch (default factory setting)
  2. Normal On/Off switch (should be configured by factory setting upon request)
I’ve installed the unit in one of my wall mounted light switches and everything seem to work as long as I doubetap the wall switch to toggle the breaker - but from the quote above I recon there is an alternate firmware for the device that would make the wall switch work as before (one click to change breaker state).
Does anyone here know if such firmware is available for me to change to myself? Or must I as it says in the manual return the device and get another config from the factory?
I would say, that if a smart switch is not smart enough to be configured with different switches, it’s good reason to return it and buy Shelly.
i have the same problem and after getting in contact with their customer service i reached the point where i have 2 different solutions:
  1. they suggested to me to buy their zigbee hub where when the device is paired then in the settings of the APP of that hub it is possible to change the trigger from “Toggle” to “push button” as they shower me in the screen shot
the name of the gateway is: Zigbee gateway-Azoula
  1. I am in contact with them to try to receive documentation about the configuration endpoint that the hub clearly is using. Since many other documentation they have report exactly the endpoints and the values to read and write i don’t see why for this particular device they could not release the documentation as well. I will keep you posted on this :slight_smile: (btw the costumer service is simply lovely)
an example of this: https://www.sunricher.com/media/resources/manual/SR-ZG9092A%20instruction.pdf
Where can I buy more of these devices?? [i have search google for mutiple model numbers without luck]
amazon stopped selling them and I still need 3 to 5 more to complete my switch panel.
I’m looking for this model SR-ZG9100A-S that does not require a neutral wire.
