Sunricher ZGRC-KEY-013 in automation event
Hello everybody,
I am using HA for quite a while now and I like it a lot! Good job everybody. But now I have a small bump on the road. I am trying to make an automation event for the remote ZGRC-KEY-013.
I did a zha_event listening and got this for one on button.
event_type: zha_event
device_ieee: b4:e3:f9:ff:fe:ec:5e:9e
unique_id: b4:e3:f9:ff:fe:ec:5e:9e:1:0x0006
device_id: 9186a1b8b5704fb02f5e706a31c11d9a
endpoint_id: 1
cluster_id: 6
command: “on”
args: []
params: {}
origin: LOCAL
time_fired: “2023-02-11T17:52:18.940102+00:00”
context:
parent_id: null
user_id: null
Now I am trying to put this in an automation and using an event as trigger but it does not work.
The code I have now:
platform: event
event_data:
context_id: 01GS0PK1NH8QA4SHE933DGJKM9
I understand that it is not working because there is way to little information but I dont now what kind of info to put in.
The actions is not difficult, it just a switch toggle. Please please help…
Hi, I have the same need to trigger a logic from an event catchup.
“Events all” node can easily display the JSON payload output on the display debug.
Should I copy the JSON like that, then define which attribute I need on the output of the node
I can’t manage to get something out doing that way.
Thank you
:wave:
I started a blueprint to configure the remote with my HA setup.
You can find it in https://github.com/lotooo/homeassistant/blob/500a4531faa4d0fb025ae671fafef32ba2eba13f/blueprints/zha-sunricher-zgrc-key-013.yaml
Hopefully it will work for you as well.
