I have 2 simple automations to turn ON and OFF lights at Sunrise and Sunset
they were working perfectly but from past few days they are not being triggered timely
tried numeric_state
conditions with elevation
but no gain, they are triggered very late or not being triggered at all
tried the suggested elevation
values and various other but still no go
I am also attaching trace files of both automations
here is my Sunrise automation:
alias: turn Garage Lights OFF when Sunrise
description: ''
- platform: sun
event: sunrise
condition: []
- service: switch.turn_off
entity_id:
- switch.left
- switch.right
- repeat:
until:
- condition: device
type: is_off
device_id: 38f7b17b094084b1ce8f53d07f472247
entity_id: switch.left
domain: switch
sequence:
- repeat:
until:
- condition: device
type: is_off
device_id: ae85597e694265fda7d634b10d2413fc
entity_id: switch.right
domain: switch
sequence: []
mode: single
here’s my Sunset automation:
alias: turn Garage Lights ON when Sunset
description: ''
- platform: sun
event: sunset
condition:
- condition: numeric_state
entity_id: sun.sun
attribute: elevation
below: '1'
- service: switch.turn_on
entity_id:
- switch.left
- switch.right
- repeat:
until:
- condition: device
type: is_on
domain: switch
- condition: device
type: is_on
domain: switch
sequence: []
mode: single
here is the trace file of Sunrise automation:
"trace": {
"last_step": "action/1/repeat/until/0/entity_id/0",
"run_id": "0",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2021-09-29T01:26:56.600289+00:00",
"finish": "2021-09-29T01:26:56.867040+00:00"
"domain": "automation",
"item_id": "1630929615984",
"trigger": "sunrise",
"trace": {
"trigger/0": [
"path": "trigger/0",
"timestamp": "2021-09-29T01:26:56.600548+00:00",
"changed_variables": {
"this": {
"entity_id": "automation.turn_garage_lights_off_when_sunrise",
"state": "on",
"attributes": {
"last_triggered": "2021-09-28T01:09:49.153543+00:00",
"mode": "single",
"current": 0,
"id": "1630929615984",
"friendly_name": "turn Garage Lights OFF when Sunrise"
"last_changed": "2021-09-28T21:19:04.756797+00:00",
"last_updated": "2021-09-28T21:19:04.756797+00:00",
"context": {
"id": "b61b87f963c0436260183d441f9859d1",
"parent_id": null,
"user_id": null
"trigger": {
"id": "0",
"idx": "0",
"platform": "sun",
"event": "sunrise",
"offset": {
"__type": "<class 'datetime.timedelta'>",
"total_seconds": 0
"description": "sunrise"
"action/0": [
"path": "action/0",
"timestamp": "2021-09-29T01:26:56.602075+00:00",
"context": {
"id": "1d6bf9e051d9837bea24b05d0c0403fe",
"parent_id": null,
"user_id": null
"result": {
"params": {
"domain": "switch",
"service": "turn_off",
"service_data": {},
"target": {
"entity_id": [
"switch.left",
"switch.right"
"running_script": false,
"limit": 10
"action/1": [
"path": "action/1",
"timestamp": "2021-09-29T01:26:56.615669+00:00"
"action/1/repeat/sequence/0": [
"path": "action/1/repeat/sequence/0",
"timestamp": "2021-09-29T01:26:56.807488+00:00",
"repeat": {
"first": false,
"index": 15
"config": {
"alias": "turn Garage Lights OFF when Sunrise",
"description": "",
"trigger": [
"platform": "sun",
"event": "sunrise"
"condition": [],
"action": [
"service": "switch.turn_off",
"target": {
"entity_id": [
"switch.left",
"switch.right"
"repeat": {
"until": [
"condition": "device",
"type": "is_off",
"device_id": "38f7b17b094084b1ce8f53d07f472247",
"entity_id": "switch.left",
"domain": "switch"
"sequence": [
"repeat": {
"until": [
"type": "is_off",
"device_id": "ae85597e694265fda7d634b10d2413fc",
"entity_id": "switch.right",
"domain": "switch"
"sequence": []
"mode": "single"
"blueprint_inputs": null,
"context": {
"parent_id": null,
"user_id": null
"logbookEntries": [
"name": "turn Garage Lights OFF when Sunrise",
"message": "has been triggered by sunrise",
"source": "sunrise",
"context_id": "1d6bf9e051d9837bea24b05d0c0403fe",
"when": "2021-09-29T01:26:56.600965+00:00",
"when": "2021-09-29T01:26:56.768886+00:00",
"name": "right",
"state": "off",
"context_entity_id": "automation.turn_garage_lights_off_when_sunrise",
"context_entity_id_name": "turn Garage Lights OFF when Sunrise",
"context_event_type": "automation_triggered",
"context_domain": "automation",
"context_name": "turn Garage Lights OFF when Sunrise",
"message": "turned off"
"when": "2021-09-29T01:26:56.864445+00:00",
"name": "left",
"state": "off",
here is the trace file of Sunset automation:
"trace": {
"last_step": "condition/0/entity_id/0",
"run_id": "0",
"state": "stopped",
"script_execution": "failed_conditions",
"timestamp": {
"start": "2021-09-27T12:48:01.254008+00:00",
"finish": "2021-09-27T12:48:01.255039+00:00"
"item_id": "1632650755935",
"trigger": "sunset with offset",
"trace": {
"trigger/0": [
"timestamp": "2021-09-27T12:48:01.254257+00:00",
"this": {
"entity_id": "automation.turn_garage_lights_on_when_sunrise_new",
"state": "on",
"attributes": {
"last_triggered": "2021-09-26T13:13:20.280792+00:00",
"mode": "single",
"current": 0,
"id": "1632650755935",
"friendly_name": "turn Garage Lights ON when Sunset"
"last_changed": "2021-09-27T07:14:37.110321+00:00",
"last_updated": "2021-09-27T07:14:37.110321+00:00",
"context": {
"id": "6aafa2926c570faf79f3d8fda0fdd76e",
"parent_id": null,
"user_id": null
"trigger": {
"id": "0",
"idx": "0",
"platform": "sun",
"event": "sunset",
"offset": {
"total_seconds": -300
"description": "sunset with offset"
"condition/0": [
"path": "condition/0",
"timestamp": "2021-09-27T12:48:01.254575+00:00",
"result": {
"result": false
"condition/0/entity_id/0": [
"path": "condition/0/entity_id/0",
"timestamp": "2021-09-27T12:48:01.254748+00:00",
"result": {
"result": false,
"state": 0.97,
"wanted_state_below": -3
"config": {
"alias": "turn Garage Lights ON when Sunset",
"description": "",
"trigger": [
"platform": "sun",
"event": "sunset",
"offset": "-00:05:00"
"condition": [
"condition": "numeric_state",
"entity_id": "sun.sun",
"attribute": "elevation",
"below": "-3.00"
"action": [
"service": "switch.turn_on",
"target": {
"entity_id": [
"switch.left",
"switch.right"
"repeat": {
"until": [
"type": "is_on",
"domain": "switch"
"type": "is_on",
"domain": "switch"
"sequence": []
"mode": "single"
"context": {
"id": "5f13008bbc3383b9adfa1917d16e6557",
"parent_id": null,
"user_id": null
"logbookEntries": []
