Because I searched a long time to find something satisfying this is quite a good basis if you want to create a sunrise animation with lights (I used yeelights)
That’s actually minutes. Because a Yeelight bug you cannot make the transitions very long (I don’t know what is the limit but I picked 60 after some trial and error). After that I wait a few minutes to start the next transition to slow it down a bit. Everything is executed in parallel so it doesn’t override the transition.
Still relatively new, but could you explain how this is triggered?
The trigger ( {{ 1==1 }} ) doesn’t make much sense to me, but the alias is interesting as I’d like this to automatically trigger when my Android phone alarm is set!
You first have to add a sensor time the time is calculated in this particular way because you have to convert it from string to time as explained by pnbrucker. The sensor.Alarm is an sensor which is created by the HTTP endpoint and send from my phone using tasker, autoalarm and Clocktask (all apps from the playstore). There are many tutorial on the internet how to do this.
I set up a task that first gets the alarm time using ‘AutoAlarm’ and then I send the time to Home Assistant using this command: curl -X POST -H "Authorization: Bearer %HASS_TOKEN" -H "Content-Type: application/json" -d '{"state": "%taskertime", "attributes": {"unit_of_measurement": "HH:MM", "friendly_name": "Alarm"}}' 192.168.1.200:8123/api/states/sensor.alarm
Where you have to have to generate a token (which can be done from the graphical user interface Account > Long Lived Access Token).
And to activate it I have a Profile which states Next alarm changed -> Execute the task described above. This Next alarm changed can be triggered by the ‘ClockTask’ app.
All in all it’s quite a hassle but it works perfectly, and doesn’t mess with your android alarm or anything so you can just set your alarm the way you are used to.
