I have a simple automation that will turn the light on before sunrise and after sunset from motion. However the boss has ever so politely requested this be altered as it’s still dark at sunrise. I would like to alter it so the automation will run for a further 45 minutes after sunrise and 45 minutes before sunset. Have I got it right with this?
condition: or
conditions:
- condition: sun
before: sunrise
before_offset: '+00:45:00'
- condition: sun
after: sunset
after_offset: '-00:45:00'
I have them as conditions not triggers. I don’t want the light to come on just because of the time of day. I want the motion sensor to be the trigger but it only trigger before sunrise/sunset so I assumed a condition would be what I wanted?
Ah sorry - then I understood your question wrong.
But your edit looks fine - does it not work?
If not - would be great if you could poste the whole automation because it does not seem that the condition is the failing part
