Where does HA pull the time associated with Sunrise and Sunset?
Thanks, Robert
Thanks, Robert
Unless things have changed in the past two months, from the sun component of core:
https://www.home-assistant.io/integrations/sun/
https://github.com/home-assistant/core/tree/dev/homeassistant/components/sun
I would assume they are calculated based on the lat/lon for your location. NOAA and others publish the formulas NOAA calculator
And the height of your location is used to refine this.
