Hi hope someone can help. I like my outside lights to come on in winter in the morning before sunrise as it’s normal to be up and about from 6.30 AM. A simple sunrise trigger with a negative offset works in winter but in summer I don’t want the lights coming on at 4AM!
I would like the lights to only come on if the time of day is after 6.30 and the sun has not risen. Any ideas how I can do this please as the UI options don’t seem to cut it!
Code looks like this currently:
alias: String lights on morning
description: ''
- platform: sun
event: sunrise
offset: '-10'
condition:
- condition: sun
before: sunrise
- service: light.turn_on
entity_id: light.patio_string_lights
- service: switch.turn_on
entity_id: switch.dining_patio_socket
mode: single
It seems odd to me to turn the lights on based on the sunrise; the lights would never turn on at a consistent time. Also, currently, your condition will always be true since the trigger is based on a sunrise offset…
I’d recommend a very similar automation, but based on time:
description: ''
- platform: time
at: "6:30:00"
condition:
- condition: sun
before: sunrise
- service: homeassistant.turn_on
entity_id:
- light.patio_string_lights
- switch.dining_patio_socket
mode: single
More Python knowledge wouldn’t help you here; this is all Home Assistant. All the information you need for stuff like this can be found in the docs. For example, here is all the information you need on triggers:
And remember to keep it simple. Just think about what you want, and try to get there in as few steps as possible. Taking the case you presented in this topic, “if it is 630am, but the sun isn’t up, turn on the porch lights.” It can be broken down like so:
Trigger: It is 6:30am
Condition: The sun is not up
Action: Turn on the porch lights
Then you can build the automation piece by piece, with a goal in mind for each piece.
you should put both of those conditions as both as triggers and conditions in your automation:
description: ''
- platform: sun
event: sunrise
- platform: time
at: '06:30:00'
condition:
- condition: sun
before: sunrise
- condition: time
after: '06:30:00'
mode: single
the above will turn on the lights at sunrise if it is after 0630 or at 0630 if the sun hasn’t risen by then.
I’m not sure how you are figuring the offset from sunrise since I’ve never seen the offset written like that (not that I use many sunrise offsets tho) so I removed it from the example above.
but however you think it might work you need to add the offset to both sunrise condition and trigger. Or you may decide you don’t need it.
and I’m not sure how you are using the “at sunrise” trigger but the condition is “before sunrise”? I left it in for illustrative purposes but I don’t think that logic will work.
I think you should just trigger at 0630 and make before sunrise a condition. but I may be missing something.
