- alias: Turn on livingroom lights when movement
platform: state
entity_id: binary_sensor.motion_sensor_158d0001236123
to: 'on'
condition:
condition: or
conditions:
- condition: sun
after: sunset
after_offset: "-00:45:00"
- condition: sun
before: sunrise
before_offset: "00:30:00"
service: homeassistant.turn_on
entity_id: group.tvrum_lampor
Im new to all this, in the config as works. I would like to add time instead of sunrise. I want it to be light after sunset, but only to 23:59 I ex.
Had domoticz before and it was so much easier, but wanna learn new stuff.
Is there also a way to use virtual switches as well?
i have something similiar, I want (exterior) lights to be on from sunset to 11pm and act motion-triggered until sunrise.
The âvirtual switchâ you mention could be a input_boolean component that is set on at sunset and switched off at 11pm
configuration.yaml:
input_boolean:
permanent_light_phase:
automations.yaml:
- alias: Control permanent light phase
trigger
- platform: sun
event: sunset
- platform: time
at: '23:00:00'
condition: []
- data:
entity_id: input_boolean.permanent_light_phase
service_template: input_boolean.turn_{% if trigger.platform == 'time' -%}off{%-
else -%}on{%- endif %}
This above controls the input_boolean.permanent_lights_phase state. Since sunset will turn it on and time will turn it of, we can easily handle both triggers by one automation.
Next, the input_boolean is used as a condition in your light rule. Remember that all conditions must pass to make an action happen:
platform: state
condition:
- condition: state
state: 'off'
- condition: state
entity_id: sun.sun
state: 'below_horizon'
- data:
service_template: homeassistant.turn_{{ trigger.to_state.state | lower }}
Btw: {{ trigger.to_state.state}} will result in âonâ or âoffâ, depending on the motionâs sensor state. We can use this so simplify the service call using service_template.
I did however discard your sunrise/sunset offsets, feel free to adjust my proposition to your needs.
Thanks for the code! Now I got a âvirtual switchâ that turns of at the time I want.
But what do ill need to add to make the group.tvrum_lampor not to turn on when permanent_light_phase is set to off? Cause now the do! Ill think my head is missing something
And a something something so the lights are on for xx minutes.
The condition part should prevent this. Without further AND or OR sub-condition all conditions must pass to make the action happen. Here, the trigger handling should stop, if input_boolean.permament_light_phase is not âoffâ
condition:
- condition: state
state: 'off'
- condition: state
entity_id: sun.sun
To let the lights on for some time on motion, it depends on the options of the device. I have Homematic motion sensors (popular in Germany), that can be configured with respect to how long they report movement. So I do this âin hardwareâ without automation.
For other devices, you could copy the above automation into two and change the trigger parts of them:
For turning the lights on:
platform: state
to: 'on'
For turning the lights off 5minutes after the sensor reported no movement any more:
- alias: Turn off livingroom lights when movement ended
platform: state
to: 'off'
for:
minutes: 5
Check indendation. YAML is a fucked up format, expressing context by indentation. trigger, condition and action must be on the same level as the alias, so it should be
platform: state
to: 'on'
condition:
- condition: state
state: 'off'
- condition: state
entity_id: sun.sun
- data:
