I am curious if it is possible to have an sunset offset depending on season.
Since the light are longer between sunset and dusk during spring and summer.
I’m pretty sure the ‘sun’ component adjusts the sunset attribute value to coincide with the actual sunset in your location. if it didn’t why call it “sunset”?
I use the sunset value for several of my automations and it reliably tracks the actual sunset throughout the year.
for example:
- id: deck_light_on_at_dusk
alias: Deck Light On at Dusk
platform: sun
event: sunset
service: homeassistant.turn_on
entity_id: light.sengled_e11g13_03070a4c_1
That’s more or less what i had from the beginning.
But the light is stronger and longer between sunset and dusk during spring and summer then autumn and winter, at least in Sweden.
I am having the same “problem”, but I am almost also in Sweden
I used to have a 30 minute after sunset trigger on the outside lights, that used to be fine. But now there is too much light for having the need to turn on outside lights 30 minutes after sunset.
Will elevation solve that, because I suppose that also not account for the sun being stronger at certain periods?
What the value would be in Denmark is hard to say. But should be slightly higher i think depending on where in Denmark you live.
Find your spot on the map and scroll down to find the elevation on this site https://www.sunearthtools.com/dp/tools/pos_sun.php?lang=en
I think you are saying that the sun is stronger in the spring and summer so you want the lights to come on later (sun further below horizon) since you want it to be more dark when the lights come on.
but if you use the elevation above 0 degrees (2.5 in your example) then doesn’t that cause the light to come on when the sun is still up (sun still above horizon)?
from the docs a positive elevation means the sun is still above the horizon.
unless you are saying that sunset as shown by the sun component isn’t actually the sun being at an elevation of 0 degrees then I still don’t see it.
I understand that the angles are different for different times of day and times of year depending on your location (i.e. 10 am at the equator has a different solar angle than 10 am somewhere due north of that location) causing the elevation angle to change more or less for every given hour at those two locations but the sunset (and sunrise) should still be at 0 degrees as referenced to the horizon at EITHER of those two locations. and that means the when the sun is at its (solar) noon position the elevation of the sun is at 90 degrees above the horizon and lowers in either direction relative to the time before or after noon.
which means that a positive elevation angle would still have the sun above the horizon no matter where you are on earth.
i can see what you are saying if the issue is that twilight is longer in the northern latitudes during summer but having an automation using a positive elevation angle shouldn’t help that problem since the sun is still above the horizon at that angle and twilight isn’t even a phenomenon occurring at that point.
