Sunset outdoor light set RGB buld to blue or green instead of white
I’ve got 3 bulbs outside, Costco Feit RGB, I’ve set them up in tuya/smartlife. I’ve got the tuya integration in HA. if I click the switch for the bulb in HA, it comes on white…
I found an automation to turn them on a sunset and off at sunrise, this automation, even though I tell it to set the bulb to white doesn’t work. garage left turns on green, right turns on blue and my porch on is green… if I go the HA and look at the bulb state they all show RGB of 255,255,255 and the bulb shows white in the UI. If I click the bulb and change the color to predefined white, it changes to white.
Is the automation broken? I don’t understand what I’m doing wrong. Here’s the automation
alias: Outside Lights ON_OFF
description: ""
  - platform: sun
    event: sunset
    offset: "-00:15:00"
  - platform: sun
    event: sunrise
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - ontime
        sequence:
          - service: light.turn_on
            metadata: {}
              rgb_color:
                - 255
                - 255
                - 255
              area_id:
                - garage_outside
                - front_porch
      - conditions:
            id:
              - offtime
        sequence:
          - service: light.turn_off
              area_id:
                - garage_outside
                - front_porch
            data: {}
I think these bulbs are actually RGBW lights not RGB. Try this:
        sequence:
            metadata: {}
              rgbw_color:
                - 0
                - 0
                - 0
                - 255
Also apparently these bulbs only last year at most. https://www.reddit.com/r/homeassistant/comments/xqe81q/anyone_have_luck_with_the_feit_electric_rgb_bulbs/
Don’t buy Tuya Wifi devices their API is terrible (Tuya zigbee are ok).
