Sunset/sunrise effect simulation with Yeelight
There are lot of nice scene in the Yeelight app and the MiHome app but I don’t know how can be implemented these scenes into HA. How can be performed a sunrise/ sunset fading effect simulation wih Yeelight ceiling lamps?
The suset maybe works with transition, but the sunrise doesn’t work. If I set transition for the light.turn_on the difference is not visible for the normal light turn on. Is there a way to give start and end parameters with time to achieve the sunrise/sunset effects?
you can use this one this one: Sunrise Simulated Wakeup Alarm
it should work in any RGB light.
Thank you! I made a Node RED flow based on this example.
