Hi I have a couple of automations and after updating to 2024.11 sunset triggers appear to have stopped working properly. It just doesn’t trigger unless setting up a delay i.e. trigger 15 mins after sunset.
I have an automation which is supposed to trigger 45 mins before sunset and it’s always worked until 2024.11 after the update it stopped working so I disabled it, re-enabled it, made changes to it deleted it and re-created it, checked the date/time on the computer and even moved home assistant entirely onto a new raspberry pi but it just won’t work.
I currently have setup 3 triggers in the automation. The original 45mins prior to sunset, at sunset and 15mins after sunset and the only one that triggers and creates a trace log is the delayed trigger (15mins after) it’s like the other two aren’t even there.
Any help would be appreciated as I’m out of ideas.
alias: "Turn on light motion control"
description: ""
triggers:
- trigger: sun
event: sunset
offset: "-00:45:00"
- trigger: sun
event: sunset
offset: 0
- trigger: sun
event: sunset
offset: "00:15:00"
conditions: []
actions:
- data: {}
entity_id: automation.light_motion
action: automation.turn_on
enabled: true
