Sunton esp32 8048s70c voice assistant
Hi there, I just finished a good working config for the Sunton esp32 8048s70c, Cheap 7" touchscreen. Basically a Box3 clone based on lvgl.
esphome:
  friendly_name: Wallpanel
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
    board_build.esp-idf.memory_type: qio_opi
    board_build.flash_mode: dio
    board_upload.maximum_ram_size: 524288
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    # Required to achieve sufficient PSRAM bandwidth
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: y
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
      CONFIG_ESPTOOLPY_FLASHSIZE_16MB: y # fix warning about 2mb found
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "qI3Jiy8ILejyQU1eyspzMsAPdRjG/dhUYMtlNQVggF4="
ota:
  - platform: esphome
    password: "7e097303fc5a5f885464acb718a72782"
wifi:
  ssid: !secret wifi_ssid
  on_connect:
    - delay: 5s  # Gives time for improv results to be transmitted
    - ble.disable:
  on_disconnect:
    - ble.enable:
    - lvgl.page.show: no_wifi_page_lvgl
  ap:
    ssid: "Wallpanel Fallback Hotspot"
    password: "7xzWoZo8ib8H"
improv_serial:
esp32_improv:
  authorizer: none
captive_portal:
i2s_audio:
  - id: audio_out
    i2s_lrclk_pin: 18
    i2s_bclk_pin: 0
  - id: audio_in
    i2s_lrclk_pin: 13  # WS fĂĽr Mikrofon
    i2s_bclk_pin: 12   # BCLK fĂĽr Mikrofon
i2c:
  sda: 19
  scl: 20
  scan: true
display:
  - id: s3_box_lcd
    platform: rpi_dpi_rgb
    dimensions:
      width: 800
      height: 480
    color_order: RGB
    invert_colors: true
    de_pin: 41
    hsync_pin: 39
    vsync_pin: 40
    pclk_pin: 42
    pclk_frequency: 12MHz # unsure about this
    data_pins:
      red:
        - 14
        - 21
        - 47
        - 48
        - 45
      green:
        - 9
        - 46
        - 3
        - 8
        - 16
        - 1
      blue:
        - 15
        - 7
        - 6
        - 5
        - 4
    update_interval: never
    auto_clear_enabled: false
lvgl:
  top_layer:
    widgets:
      - button:
          align: TOP_MID
          hidden: true
          width: 200
          height: 100
          bg_color: black
          widgets:
            - label:
                text: "00:00"
                align: CENTER
                text_color: white
                text_font: font_timer
      - bar:
          width: 800
          height: 20
          animated: true
          max_value: 100
          anim_time: 300ms
          bg_opa: TRANSP
          value: 0
          indicator:
            bg_color: green
          align: BOTTOM_LEFT
          hidden: true
      - button:
          x: 120
          y: 200
          hidden: true
          bg_color: red
          checkable: true
          width: 100
          height: 50
          widgets:
            - label:
                align: center
                text: "Stop"
                text_color: black
          on_value:
            - switch.turn_off: timer_ringing
  buffer_size: 60%
  pages:
    - id: idle_page_lvgl
      bg_color: 0x000000
      on_long_press:
        - switch.toggle: mute
      widgets:
        - image:
            align: CENTER
            src: casita_idle
    - id: listenig_page_lvgl
      widgets:
        - image:
            align: CENTER
            src: casita_listening
    - id: replying_page_lvgl
      widgets:
        - animimg:
            align: CENTER
            src: [ casita_replying, casita_listening ]
            duration: 500ms
        - label:
            align: TOP_LEFT
            width: 780
            pad_top: 20
            recolor: true
            text: text_request
            text_font: font_request
        - label:
            align: BOTTOM_LEFT
            width: 780
            recolor: true
            pad_bottom: 20
            text: text_response
            text_font: font_response
    - id: thinking_page_lvgl
      widgets:
        - image:
            align: CENTER
            src: casita_thinking
    - id: error_page_lvgl
      bg_color: 0x000000
      widgets:
        - image:
            align: CENTER
            src: casita_error
    - id: no_ha_page_lvgl
      bg_color: black
      widgets:
        - image:
            align: CENTER
            src: error_no_ha
    - id: no_wifi_page_lvgl
      widgets:
        - image:
            align: CENTER
            src: error_no_wifi
    - id: initializing_page_lvgl
      bg_color: 0x000000
      widgets:
        - image:
            align: CENTER
            src: casita_initializing
    - id: timer_finished_page_lvgl
      widgets:
        - image:
            align: CENTER
            src: casita_timer_finished
            on_press:
touchscreen:
  platform: gt911
  address: 0x5D
  update_interval: 16ms
  transform:
    mirror_x: true
    swap_xy: true
speaker:
  - platform: i2s_audio
    i2s_audio_id: audio_out
    dac_type: external
    i2s_dout_pin: 17
    buffer_duration: 600ms
media_player:
  - platform: speaker
    announcement_pipeline:
      speaker: box_speaker
      num_channels: 1
    files:
      - id: timer_finished_wave_file
        file: sound/timer_finished.wav
    on_announcement:
      - if:
          condition:
            microphone.is_capturing:
          then:
            - voice_assistant.stop:
    on_idle:
      - voice_assistant.start_continuous
microphone:
    i2s_audio_id: audio_in
    adc_type: external
    i2s_din_pin: 11
    channel: left
    sample_rate: 16000
    bits_per_sample: 16bit
output:
  - id: backlight_output
    platform: ledc
    pin: 2
light:
  - platform: monochromatic
    icon: "mdi:television"
    entity_category: config
    output: backlight_output
    restore_mode: RESTORE_DEFAULT_ON
    default_transition_length: 250ms
voice_assistant:
  microphone: box_microphone
  use_wake_word: true
  noise_suppression_level: 2
  #vad_threshold: 3
  auto_gain: 24dBFS
  volume_multiplier: 3.0
  on_start:
    - lvgl.page.show: idle_page_lvgl
  on_listening:
    then:
    - lvgl.page.show: listenig_page_lvgl
  on_idle:
  on_stt_vad_end:
    - lvgl.page.show: thinking_page_lvgl
  on_stt_end:
    - lvgl.widget.enable: request
    - lvgl.label.update:
        text: !lambda return x;
  on_tts_start:
    - lvgl.widget.enable: response
  on_tts_stream_start:
    then:
    - lvgl.page.show: replying_page_lvgl
  on_tts_stream_end:
    then:
    - wait_until:
        speaker.is_stopped
    - lvgl.widget.disable: response
    - lvgl.widget.disable: request
  on_end:
    - wait_until:
        and:
          - not:
              media_player.is_announcing:
          - not:
              voice_assistant.is_running:
  on_error:
    -  then:
          - lvgl.page.show: error_page_lvgl
          - delay: 5s
  on_client_connected:
    - wait_until:
        not: ble.enabled
    - voice_assistant.start_continuous:
  on_client_disconnected:
  on_timer_started:
    - lvgl.widget.show:
        - timer_bg
        - timer_bar
  on_timer_cancelled:
    - lvgl.widget.hide:
        - timer_bg
        - timer_bar
  on_timer_tick:
        text: !lambda |-
          if (timers.empty()) return std::string("00:00");
          auto timer = timers[0];
          int minutes = timer.seconds_left / 60;
          int seconds = timer.seconds_left % 60;
          char buffer[6];
          snprintf(buffer, sizeof(buffer), "%02d:%02d", minutes, seconds);
          return std::string(buffer);
    - lvgl.bar.update:
        value: !lambda |-
          if (timers.empty()) return 0;
          if (timer.total_seconds == 0) return 0;
          return static_cast<int>(100.0 * timer.seconds_left / timer.total_seconds);
  on_timer_finished:
    - lvgl.widget.hide:
        - timer_bg
        - timer_bar
    - switch.turn_on: timer_ringing
    - lvgl.widget.show: timer_stop
    - lvgl.page.show: timer_finished_page_lvgl
    - while:
        condition:
          switch.is_on: timer_ringing
        then:
          - media_player.speaker.play_on_device_media_file:
              media_file: timer_finished_wave_file
              announcement: true
          - wait_until:
          - wait_until:
              not:
switch:
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
      # Stop playing the alarm
      - media_player.stop:
          announcement: true
      - lvgl.widget.hide: timer_stop
    on_turn_on:
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - delay: 15min
    icon: "mdi:microphone-off"
    optimistic: true
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_off:
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
            - light.turn_on: led
    on_turn_on:
      - light.turn_off: led
image:
  - file: image/error_320_240.png
    resize: 640x480
    type: RGB565
    transparency: alpha_channel
  - file: image/idle_320_240.png
    resize: 640x480
    type: RGB565
  - file: image/listening_320_240.png
    resize: 640x480
    type: RGB565
  - file: image/thinking_320_240.png
    resize: 640x480
    type: RGB565
  - file: image/replying_320_240.png
    resize: 640x480
    type: RGB565
  - file: image/loading_320_240.png
    resize: 640x480
    type: RGB565
  - file: image/error-no-wifi.png
    resize: 640x480
    type: RGB565
  - file: image/error-no-ha.png
    resize: 640x480
    type: RGB565
  - file: image/timer_finished_320_240.png
    resize: 640x480
    type: RGB565
font:
  - file:
      type: gfonts
      family: Figtree
      weight: 400
      italic: true
    glyphsets: GF_Latin_Core
  - file:
      type: gfonts
      family: Figtree
      weight: 400
    #glyphs: ${allowed_characters}
  - file:
      type: gfonts
      family: Figtree
      weight: 400
button:
  - platform: restart
Just attach a speaker to the output of the board and connect an i2c microphone.
Cheers
Doesn’t work here… speakers are silent, although log (and media player) says it plays.
Only way i could get my speaker to work was via mixer:
i2s_audio:
  - id: i2s_out
    i2s_lrclk_pin: GPIO18
    i2s_bclk_pin: GPIO0
speaker:
    dac_type: external
    i2s_dout_pin: GPIO17
    sample_rate: 48000
    channel: stereo
    timeout: never
    buffer_duration: 100ms
  - platform: mixer
    output_speaker: speaker_id
    source_speakers:
      - id: announcement_spk_mixer_input
      - id: media_spk_mixer_input
  - platform: resampler
    output_speaker: media_spk_mixer_input
    output_speaker: announcement_spk_mixer_input
media_player:
  - platform: speaker
    name: "Speaker Media Player"
    buffer_size: 100000
    media_pipeline:
        speaker: media_spk_resampling_input
        sample_rate: 21000
        num_channels: 2
        format: WAV
        speaker: announcement_spk_resampling_input
        sample_rate: 21000
        num_channels: 1
        format: WAV
But, “side effect” of built-in audio is nasty few kHz sound if backlight is less than 100% - noise from light pwm is played on speakers.
Nice looks good! What microphone did you use?
Do you have a GitHub repo so we can get your graphic files?
Wich Board Version do you got?
Depends on the version you need to change bclk pin to 19
And I used an inmp441 microphone
The pictures are out of the voice-assistant github.
It should be the noise from the backlight control MOSFET.
Thanks for this extremely useful information. I purchased my board recently and it’s version 1.4. It is also using GPIO 0 for the I2S_BCLK.
When I googled this board I only found the information on the 1.0 version and I thought I needed to use pin 19. This of course did not work and I don’t think audio would work on a 1.0 board at all as this pin is shared with the touch screen.
When I boot the board I do initially get static on the speaker but once I play sound everything is fine. The audio amp on this board is very low power so I need max volume just to hear it at all.
Now I just need to get a mic so I can try the voice assistant. They are 3 for $9USD on Amazon!
I’ll check my version when i get home, i guess it could be that i have a different one, yes. My backlight works, though, it’s just as NIUB said, mosfet causes noise, which makes whole thing almost useless. Since i rarely keep my LCD’s at full brightness when idle speaker would “beep” the whole time except when i use my lcd. I make them in a way that brightness goes up to 100% only at touch (when i use it) and then goes down after set time of no-use.
But, recently some things were done/corrected regarding speaker part in esphome, so it could be that some bug still remained…?
I do hear some constant low level noise on my speaker but I have to hold my ear directly to the speaker to hear it so it’s not annoying. I would attribute this to pour quality audio components. Based on the schematic for this board the audio piece costs 20 cents or less.
My display is version 1.4.
I don’t need sound right now anyway, i just wanted to test it. I guess when/if i will need it i’ll rather add external I2S audio board, since they are dirt cheap on aliexpress and i have good experience with them. Audio chip on this board is some unknown variant anyway…
Have you seen a good one with both a DAC and an amp?
Yes, i use “TENSTAR MAX98357 I2S 3W Class D Amplifier Breakout Interface Dac Decoder Module” aliexpress modules in a couple of speakers (with esp32 wemos d1 mini) around my house as warning audio players (like doorbell, gate open etc…) and together with two 3W speakers they work quite well. They cost around 2€ per piece and they are well supported in esphome.
That is a really nice board I see a few vendors sell 10pcs for only a few dollars.
You said you used two speakers with it. It looks like it’s only mono and supports a single 3w speaker.
Hi, I just use one speaker. No external DAC.
I tried sound with dimming the backlight and had no problems at all. I got the version 1.3
Yes, it’s mono, i use two speakers because i have a bunch of small 8 ohm 3W speakers, so since board is 3W at 4 ohms i wired 2 of them in parallel. That way i get “even more bang for my buck”… :grinning:
Just an update on the yaml, it didn’t work anymore.
esphome:
  platformio_options:
esp32:
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: "y"
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "Y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "Y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "Y"
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
api:
  encryption:
ota:
  - platform: esphome
wifi:
  on_connect:
    - ble.disable:
  on_disconnect:
    - ble.enable:
  ap:
improv_serial:
esp32_improv:
  authorizer: none
captive_portal:
i2s_audio:
  - id: audio_out
    i2s_lrclk_pin: 18
    i2s_bclk_pin: 0
  - id: audio_in
i2c:
  sda: 19
  scl: 20
  scan: true
display:
  - id: s3_box_lcd
    dimensions:
      width: 800
      height: 480
    color_order: RGB
    invert_colors: true
    de_pin: 41
    hsync_pin: 39
    vsync_pin: 40
    pclk_pin: 42
    data_pins:
      red:
        - 14
        - 21
        - 47
        - 48
        - 45
      green:
        - 9
        - 46
        - 3
        - 8
        - 16
        - 1
      blue:
        - 15
        - 7
        - 6
        - 5
        - 4
lvgl:
  top_layer:
    widgets:
      - button:
          align: TOP_MID
          hidden: true
          width: 200
          height: 100
          bg_color: black
          widgets:
            - label:
                text: "00:00"
                align: CENTER
                text_color: white
      - bar:
          width: 800
          height: 20
          animated: true
          min_value: 0
          max_value: 100
          anim_time: 300ms
          bg_opa: TRANSP
          value: 0
          indicator:
            bg_color: green
          align: BOTTOM_LEFT
          hidden: true
      - button:
          x: 120
          y: 200
          hidden: true
          bg_color: red
          checkable: false
          width: 100
          height: 50
          on_change:
            then:
          widgets:
            - label:
                align: center
                text: "Stop"
                text_color: black
  buffer_size: 25%
  pages:
      bg_color: 0x000000
      on_long_press:
      widgets:
        - image:
            align: CENTER
            src: casita_idle
      widgets:
        - image:
            align: CENTER
      widgets:
        - animimg:
            align: CENTER
            duration: 500ms
        - label:
            align: TOP_LEFT
            width: 780
            pad_top: 20
            recolor: true
            text: text_request
        - label:
            align: BOTTOM_LEFT
            width: 780
            recolor: true
            pad_bottom: 20
            text: text_response
      widgets:
        - image:
            align: CENTER
      bg_color: 0x000000
      widgets:
        - image:
            align: CENTER
            src: casita_error
      bg_color: black
      widgets:
        - image:
            align: CENTER
            src: error_no_ha
      widgets:
        - image:
            align: CENTER
            src: error_no_wifi
      bg_color: 0x000000
      widgets:
        - image:
            align: CENTER
      widgets:
        - image:
            align: CENTER
            on_press:
touchscreen:
  platform: gt911
  address: 0x5D
  transform:
    mirror_x: true
    swap_xy: true
speaker:
    dac_type: external
    i2s_dout_pin: 17
    buffer_duration: 200ms
    sample_rate: 16000
media_player:
  - platform: speaker
      format: WAV
      num_channels: 1
    codec_support_enabled: false
    #buffer_size: 4000
    files:
    on_announcement:
      - if:
          condition:
          then:
    on_idle:
microphone:
    adc_type: external
    i2s_din_pin: 11
    channel: left
    sample_rate: 16000
    #bits_per_sample: 16bit
    correct_dc_offset: true
output:
    platform: ledc
    pin: 2
light:
voice_assistant:
  use_wake_word: true
  #vad_threshold: 3
  auto_gain: 24dBFS
  on_start:
  on_listening:
    then:
  on_idle:
  on_stt_vad_end:
  on_stt_end:
  on_tts_start:
    then:
  on_tts_stream_end:
    then:
    - wait_until:
        speaker.is_stopped
  on_end:
    - wait_until:
        and:
          - not:
          - not:
  on_error:
    -  then:
          - delay: 5s
    - wait_until:
        not: ble.enabled
  on_timer_started:
    - lvgl.widget.show:
        - timer_bg
        - timer_bar
  on_timer_cancelled:
    - lvgl.widget.hide:
        - timer_bg
        - timer_bar
  on_timer_tick:
        text: !lambda |-
          char buffer[6];
    - lvgl.bar.update:
        value: !lambda |-
  on_timer_finished:
    - lvgl.widget.hide:
        - timer_bg
        - timer_bar
    - while:
        condition:
        then:
              announcement: true
          - wait_until:
          - wait_until:
              not:
switch:
    optimistic: true
    on_turn_off:
          announcement: true
    on_turn_on:
      - delay: 15min
    optimistic: true
    on_turn_off:
      - if:
          condition:
            not:
          then:
    on_turn_on:
image:
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
    resize: 640x480
    type: RGB565
font:
  - file:
      type: gfonts
      family: Figtree
      weight: 400
      italic: true
  - file:
      type: gfonts
      family: Figtree
      weight: 400
  - file:
      type: gfonts
      family: Figtree
      weight: 400
button:
  - platform: restart
Do you have a wiring diagram of the microphone connection
Can you share the yaml u use based on the current version of esphome?
i try this code below but the screen is not stable
display:
  - platform: mipi_rgb
    model: ESP32-8048S070
    data_pins:
      red:   [14, 21, 47, 48, 45]
      green: [9, 46, 3, 8, 16, 1]
      blue:  [15, 7, 6, 5, 4]
    de_pin: 41
    hsync_pin: 39
    vsync_pin: 40
    pclk_pin: 42
    pclk_frequency: 16MHz
    hsync_front_porch: 210
    hsync_pulse_width: 30
    hsync_back_porch: 16
    vsync_front_porch: 22
    vsync_pulse_width: 13
    vsync_back_porch: 10
    pclk_inverted: true
    color_order: RGB
    dimensions:
      width: 800
      height: 480
This works well.
