Anyone know what I’m doing wrong? I can’t seem to get this to work. It doesn’t turn on at 5pm. The time is correct on the Raspberry Pi. I can turn on and off the light in HA.
I’m using this:
SUPERNIGHT WiFi Wireless LED Smart Controller
Got it working…
Scenes.yaml:
- name: LED_Red_10
entities:
group.LED_group:
state: 'on'
color_name: 'Red'
brightness: 10
JSV
(Joakim Svärdh)
March 31, 2018, 9:05pm
2
How does the configuration of the led strip look like? are you able to control it from HA?
configuration.yaml:
light:
- platform: flux_led
devices:
xxx.xxx.xxx.xxx: #network ip address
mode: "rgb"
counter:
accent_color_num:
initial: 0
step: 1
group:
Kitchen_Lighting_Above_Cabinet:
name: Kitchen Lighting Above Cabinet
entities:
- counter.accent_color_num
- light.Kitchen_Ceiling_LED
script:
color_scenes:
sequence:
- service: counter.increment
entity_id: counter.accent_color_num
- service: scene.turn_on
data_template:
entity_id: >
scene.color_{{ states.counter.accent_color_num.state }}
automation:
- alias: LEDs on
platform: time
minutes: '/7'
seconds: '/30'
condition:
- condition: time
after: '17:00'
before: '23:00'
- service: script.color_scenes
- alias: LEDs off
platform: time
at: '16:55:00'
at: '23:01:00'
- service: light.turn_off
entity_id:
- service: counter.reset
scene: !include scenes.yaml
scenes.yaml
- name: LED_off
entities:
group.LED_group:
state: 'off'
- name: color_1
entities:
light.Kitchen_Ceiling_LED:
state: 'on'
rgb_color: [255,248,224]
brightness: 200
- name: color_2
entities:
state: 'on'
rgb_color: [255,245,209]
brightness: 200
- name: color_3
entities:
state: 'on'
rgb_color: [255,241,193]
brightness: 200
#Note: I really have 48 scenes, I just listed the first 3 and the last 3.
- name: color_46
entities:
state: 'on'
rgb_color: [34,12,46]
brightness: 200
- name: color_47
entities:
state: 'on'
rgb_color: [22,8,30]
brightness: 200
- name: color_48
entities:
state: 'on'
rgb_color: [11,4,15]
brightness: 200
makani47
(Michael)
April 5, 2018, 7:38pm
4
I have that same device and I swear that is the only thing in my 5:00 turn on scene that won’t turn on. Works if I manually use it in home assistant though. My main issue with that device is every time the power at the house flicks off for something, the device has to be set back up again using the Magic Home app or else it won’t work in Home Assistant. I even assigned it a static IP. It basically forgets its wifi settings.
mattlward
(Matt Ward)
July 25, 2018, 4:28am
5
I am trying to make one of the SuperNight SMD 2835 kits work with HA. Alexa controls the device fine as does my phone. But the light component returns the following errors:
Running the latest Hass.io on an RPI 2.
2018-07-24 23:15:44 WARNING (SyncWorker_10) [homeassistant.components.light.flux_led] Failed to connect to bulb 192.168.1.171, teststrip
2018-07-24 23:15:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.teststrip, old_state=None, new_state=<state light.teststrip=unavailable; friendly_name=teststrip, supported_features=21 @ 2018-07-24T23:15:44.944005-05:00>>
Here is my base config for the strip:
devices:
192.168.1.171:
mode: "rgb"
I can ping it at the DHCP static assigned address and it goes away when I power it off. It shows up in my router as and ESP device.
Ideas?
