Supervise or Not to Supervise That is the Question
Based on what you’ve said, If you’re pretty knowledgeable with linux use supervise version, if not use HASOS. I’ve used the supervised version for years for exactly the reasons you’ve mentioned. I’ve only had minor issues as the developers pull functionality into the HA code base. The network management items is probably the only thing that has really been an issue. In my situation I utilize cellular as a backup and to this point in time HA OS still has no way of implementing such a solution. All things are possible with HA supervised.
