I have supervised HA installed on VirtualBox. The network is configured as ‘bridged’ for both the LAN and Wifi adapters. I allocated to it static IPs 192.168.1.36 and 192.168.1.37 in the router.
The issue is that tthe HA loses its IP about a day later. Even when I configured hte HA itself to have the same static IP addresses it is disconnected about a day after it starts.
The command ‘network info enp0s17’ shows the (localy static) IP address 192.168.1.36 and ‘network info enp0s8’ shows the (localy static) IP address 192.168.1.37, but the machine is not accessible from other devices in the local LAN.
Even ping from it to the router in IP 192.168.1.1 fails.
Any idea how to make the HA keep its network connectivity?
