Supervised in oracle cloud infrastructure (unsupported)f
I’m trying to install supervised installation of HA in OCI so i get all addons etc.
I created aarch64 instance with ubuntu 20.04 as it seemed closest to debian 11 and selected raspberryPi4 64 as the supervised version i’m going with. [I tried qemuarm-64 but got the same results]
Seems to be running
But I can’t access it on publicio:8123. Simply no response
root@has:/home/ubuntu# ufw status
Status: inactive
My guess is that issue is with ubuntu firewall or oracle created ubuntu firewall or something like that.
journalctl -f
reports no related errors currently
How to run (unsupported) supervised installation in oci and be able to access it?
Update:
Solution
apt install firewalld
firewall-cmd --permanent --add-port=8123/tcp
firewall-cmd --reload
firewall-cmd --list-ports
systemctl start firewalld
systemctl status firewalld
basically install the same firewall thing that is on oracle linux 8
sadly all addons end up with 502 bad gateway
tried
systemctl status iptables.service
systemctl start iptables.service
iptables -L
Update2: so i finally found a way to install debian in free OCI
mkdir -p /boot/efi/EFI/rescue && cd /boot/efi/EFI/rescue
wget https://boot.netboot.xyz/ipxe/netboot.xyz-arm64.efi
and evrything now seems to be working
In Oracle Cloud, you’ll need to make sure the VCN’s security list or VNIC’s network security group permits ingress on that port too.
so did I understand correctly that you managed to get Hassio started on the oracle cloud?
Have you used the free instance it provides?
Do you have a mini guide on how to install everything?
TLDR from the first post
Are there some new information for installing the Supervised Version on OCI?
Can you give a more detailed description?
