Supervised-installation do not start with new docker-ce 20.10.0 on Debian 10
i had installed via the supervised-installer ( https://github.com/home-assistant/supervised-installer ) on Debian 10. After the last update of Docker the container of the supervised-installation do not start automatically when I restarted the system. Only after downgrading docker-ce from 20.10.0 to 19.03.14 it was working again.
Is somebody else here with the same problem?
It’s explained in ADR0014.
I understood that specs in the way that the docker-version has to be 19.03 or later and so I will not get a problem with docker 20.x
Only 19.03 Not later.
ok, thank you for that information.
Any advice on how to roll back docker versions for a numpty that might’ve upgraded before reading this?!
My HA doesn’t start up anymore :frowning:
I’m sure the documentation should be corrected!
Docker CE >= 19.03 in ADR0014 means 19.03 or later.
And 20.10 later then 19.03…
Use these commands to downgrade
sudo apt remove docker-ce docker-ce-cli
sudo rm -rf /var/lib/docker
VERSION=19.03.14 sh get-docker.sh
At my Debian 10 I used the following commands:
apt update
apt-cache madison docker-ce
apt-cache madison docker-ce-cli
apt install docker-ce=5:19.03.14~3-0~debian-buster docker-ce-cli=5:19.03.14~3-0~debian-buster
I was asked if I want to downgrade the 2 package and I agreed. After that i restarted the system and HA was starting as expected. Now I have be carefull when I install updates for the system until the supervised-installer is usable with docker-ce newer as 19.03.xx
