since supervisor updated to 2021.3.0, i receive this error
i tested a new , did the first 3 simple steps, and again the same error ??
21-03-03 19:11:51 ERROR (MainThread) [supervisor.jobs] Unhandled exception: 'NoneType' object has no attribute 'is_file'
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 100, in wrapper
return await self._method(*args, **kwargs)
File "/usr/src/supervisor/supervisor/addons/__init__.py", line 182, in install
await addon.instance.install(store.version, store.image)
File "/usr/src/supervisor/supervisor/utils/__init__.py", line 32, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/supervisor/supervisor/docker/addon.py", line 491, in _install
self._build(version)
File "/usr/src/supervisor/supervisor/docker/addon.py", line 500, in _build
build_env = AddonBuild(self.coresys, self.addon)
File "/usr/src/supervisor/supervisor/addons/build.py", line 32, in __init__
super().__init__(
File "/usr/src/supervisor/supervisor/utils/common.py", line 59, in __init__
self.read_data()
File "/usr/src/supervisor/supervisor/utils/common.py", line 72, in read_data
if self._file.is_file():
AttributeError: 'NoneType' object has no attribute 'is_file'
Add a blank build.yaml
file in the same directory
ok, fixed now, is new feature?
It’s a bug
@ludeeus , is this also related?
when i try in config.json this :
"host_network": false
i receive this error when i start it :
ioctl SIOCSIFNAME rename: No such file or directory
not sure, didnt try on supervisor 2021.2.3 , when i set it to true , it works
Not related at all
