I’m hoping someone would be able to direct me to a resolution. I’ve been trying to update Supervisor for the last few days.I’ve never had any issues updating anything in the past. Every time I attempt to update it fails with “Update of Supervisor failed: local error: tls: bad record MAC”. I’ve searched the forum and haven’t found a solution that works for me. I’ve also googled and everything is coming up short. below are the logs for when I attempt to update. Any ideas I could try or an direction whatsoever would be greatly appreciated!
- Installation method Home Assistant OS
- Core 2025.10.4
- Supervisor 2025.10.0
- Operating System 16.2
- Frontend 20251001.4
SUPERVISOR LOG
2025-11-06 10:40:38.462 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2025-11-06 10:40:38.577 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2025-11-06 10:40:38.682 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2025.11.1
2025-11-06 10:40:38.682 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2025.11.1.
2025-11-06 10:42:25.466 ERROR (SyncWorker_1) [supervisor.docker.manager] local error: tls: bad record MAC
2025-11-06 10:42:25.467 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-06 10:42:25.468 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-06 10:42:25.469 CRITICAL (MainThread) [supervisor.supervisor] Update of Supervisor failed: local error: tls: bad record MAC
CORE LOG
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:317
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 9:51:13 AM (3 occurrences)
Last logged: 10:42:25 AM
[140654260239584] Error during service call to update.install: Error updating Home Assistant Supervisor: Update of Supervisor failed: Get "https://pkg-containers.githubusercontent.com/ghcr1/blobs/sha256:3161d9c93dff1e24ae1b0b553300881d508569ff67096dc7576850dc4fc6aa21?se=2025-11-06T15%3A00%3A00Z&sig=0Cjc8RgFfdIPP4yvraoTL6vBmtCsVcVXxzkh0Eb7INc%3D&ske=2025-11-07T06%3A45%3A57Z&skoid=fb3d2a07-ec6c-4fe4-aced-9efe0fd2fe1a&sks=b&skt=2025-11-06T06%3A45%3A57Z&sktid=398a6654-997b-47e9-b12b-9515b896b4de&skv=2025-01-05&sp=r&spr=https&sr=b&sv=2025-01-05&hmac=7fa4a5c609ace9bfd15f5fdb3122541277a514e3d1853be5b557c84692e07406": net/http: TLS handshake timeout
[140653837828320] Error during service call to update.install: Error updating Home Assistant Supervisor: Update of Supervisor failed: local error: tls: bad record MAC
HOST LOG
2025-11-06 15:40:38.578 DRHOMEASSISTANT os-agent[455]: INFO: 2025/11/06 10:40:38 apparmor.go:45: Load AppArmor profile '/mnt/data/supervisor/apparmor/hassio-supervisor'.
2025-11-06 15:40:38.681 DRHOMEASSISTANT os-agent[455]: INFO: 2025/11/06 10:40:38 apparmor.go:53: Load profile '/mnt/data/supervisor/apparmor/hassio-supervisor':
2025-11-06 15:40:40.273 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:40.273739863-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:40:40.491 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:40.491489370-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:40:41.006 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:41.006288867-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:40:46.054 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:46.054682114-05:00" level=info msg="Download failed, retrying (2/5): local error: tls: bad record MAC"
2025-11-06 15:40:46.316 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:46.316115193-05:00" level=info msg="Download failed, retrying (2/5): local error: tls: bad record MAC"
2025-11-06 15:40:49.637 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:49.636859625-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:40:54.944 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:54.944206871-05:00" level=info msg="Download failed, retrying (2/5): local error: tls: bad record MAC"
2025-11-06 15:40:56.362 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:56.362278924-05:00" level=info msg="Download failed, retrying (3/5): local error: tls: bad record MAC"
2025-11-06 15:40:56.675 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:40:56.675580243-05:00" level=info msg="Download failed, retrying (3/5): local error: tls: bad record MAC"
2025-11-06 15:41:05.280 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:05.280535413-05:00" level=info msg="Download failed, retrying (3/5): local error: tls: bad record MAC"
2025-11-06 15:41:11.877 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:11.877530124-05:00" level=info msg="Download failed, retrying (4/5): local error: tls: bad record MAC"
2025-11-06 15:41:12.073 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:12.073724437-05:00" level=info msg="Download failed, retrying (4/5): local error: tls: bad record MAC"
2025-11-06 15:41:20.600 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:20.599902786-05:00" level=info msg="Download failed, retrying (4/5): local error: tls: bad record MAC"
2025-11-06 15:41:32.383 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:32.383504991-05:00" level=error msg="Download failed after 5 attempts: local error: tls: bad record MAC"
2025-11-06 15:41:32.898 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:32.898003929-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:41:33.695 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:33.695537506-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:41:38.200 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:38.200732885-05:00" level=info msg="Download failed, retrying (2/5): local error: tls: bad record MAC"
2025-11-06 15:41:39.167 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:39.166896278-05:00" level=info msg="Download failed, retrying (2/5): local error: tls: bad record MAC"
2025-11-06 15:41:41.545 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:41.545509574-05:00" level=error msg="Download failed after 5 attempts: local error: tls: bad record MAC"
2025-11-06 15:41:41.859 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:41.859807365-05:00" level=info msg="Download failed, retrying (1/5): local error: tls: bad record MAC"
2025-11-06 15:41:48.995 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:48.995720599-05:00" level=info msg="Download failed, retrying (3/5): local error: tls: bad record MAC"
2025-11-06 15:41:49.522 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:41:49.521990290-05:00" level=info msg="Download failed, retrying (3/5): local error: tls: bad record MAC"
2025-11-06 15:42:04.428 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:42:04.428704494-05:00" level=info msg="Download failed, retrying (4/5): local error: tls: bad record MAC"
2025-11-06 15:42:04.947 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:42:04.947193612-05:00" level=info msg="Download failed, retrying (4/5): local error: tls: bad record MAC"
2025-11-06 15:42:25.059 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:42:25.059500503-05:00" level=error msg="Download failed after 5 attempts: local error: tls: bad record MAC"
2025-11-06 15:42:25.391 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:42:25.391637537-05:00" level=error msg="Download failed after 5 attempts: local error: tls: bad record MAC"
2025-11-06 15:42:25.398 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:42:25.398207218-05:00" level=info msg="Attempting next endpoint for pull after error: local error: tls: bad record MAC"
2025-11-06 15:42:25.402 DRHOMEASSISTANT dockerd[586]: time="2025-11-06T10:42:25.402877337-05:00" level=info msg="Layer sha256:7405e81a7bbbbd4e98b593788f544b86a0c093a9f611d1b18450da04cf3a3a04 cleaned up"
