Supervisor 234 not supported on Raspbian GNU/Linux 10 (buster)? Per error log
Found a fix, in this link https://github.com/home-assistant/core/issues/41336
it states the wake_on_lan integration causes dns error when not using the deprecated host: parameter
i put my host: ip parameter back in my configuration.yaml restarted home assistant.
i don’t need the other workaround putting a host entry for none.local.hass.io in file /usr/share/hassio/dns/hosts
