Supervisor and/or Hass.io missing
Hello I have a question about the installation.
I install after this manual.
Very works fine, but after first log I miss the Supervisor button.
What I have done wrong?
I think this is a know Problem but I was not able to find a reason in this forum.
I hope anyone can help me.
MrKrise (Chris)
You installed Home Assistant Core in a virtual environment. No way you can get the Supervisor Tab.
If you want to install Home Assistant Supervised on Raspbian Lite, follow these instructions :
Hi Francis,
ok this is the problem, thank for your link.
I will try this way.
Now it works, thank you.
Hi @MrKrise … can you guide me on how you installed your version?
Which virtual machine software did you use for the Pi?
You can’t use virtual machine software on a Pi.
The link posted above does not work anymore. Use this one :
that is the classic installation. That is not an answer for installing hassio on raspbian
See the link just above your reply.
What about HA OS? I am running the image from within unRAID’s VM. Shouldn’t there be a supervisor tab?
I also have missing tab supervisor someone do you know why?
many thanks.
