I’ve been coping for some time with the Unifi controller all of a sudden becoming unavailable (posted on this here. I’m becoming an expert in restoring that now (reinstall controller and readopt APs, rename all clients and assign new fingerprints - yeah I’m freaky like that
. Unfortunately backup restore does not work - tried that).
I’m trying to find out what it could be. Last time I upgraded to core-2021.6.0, Unifi controller was inacessible again and this morning when upgrading to core-2021.6.1 it continued to work fine. Just an hour ago, I had a power outage and post that all came back up after a clean restart but again the Unifi controller became inacessible…
In the system logs I see this error : [supervisor.api.middleware_security] Invalid token for access /network/interface/default/info could this be related and how can I solve it?
Does anyone have a good suggestion? I’m afraid if I do a clean build with the backup restore, I’ll import the same issue again…
Thanks in advance!!
fulll log:
21-06-04 15:57:18 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio homeassistant/armv7-hassio-audio with version 2021.04.0 - 172.30.32.4
21-06-04 15:57:18 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-cli with version 2021.05.1
21-06-04 15:57:18 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
21-06-04 15:57:20 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/armv7-hassio-cli with version 2021.05.1 - 172.30.32.5
21-06-04 15:57:20 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-observer with version 2020.10.1
21-06-04 15:57:20 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-multicast with version 2021.04.0
21-06-04 15:57:20 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
21-06-04 15:57:21 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast homeassistant/armv7-hassio-multicast with version 2021.04.0 - Host
21-06-04 15:57:21 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-04 16:27:41 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-04 16:27:41 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi4-homeassistant with version 2021.6.1
21-06-04 16:27:41 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 10 Home Assistant secrets
21-06-04 16:27:42 INFO (MainThread) [supervisor.hassos] Detect Home Assistant Operating System 5.13 / BootSlot A
21-06-04 16:27:43 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7ad98f9c repository
21-06-04 16:27:43 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-06-04 16:27:43 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-06-04 16:27:43 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
21-06-04 16:27:44 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
21-06-04 16:27:44 INFO (MainThread) [supervisor.addons] Found 11 installed add-ons
21-06-04 16:27:44 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-mosquitto with version 6.0.1
21-06-04 16:27:44 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-armv7 with version 0.104.3
21-06-04 16:27:44 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ssh/armv7 with version 8.2.3
21-06-04 16:27:44 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to zigbee2mqtt/zigbee2mqtt-armv7 with version 1.18.1-1
21-06-04 16:27:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-configurator with version 5.3.1
21-06-04 16:27:44 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/unifi/armv7 with version 0.23.0
21-06-04 16:27:44 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-samba with version 9.5.0
21-06-04 16:27:44 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-duckdns with version 1.12.5
21-06-04 16:27:44 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to esphome/esphome-hassio-armv7 with version 1.18.0
21-06-04 16:27:44 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/glances/armv7 with version 0.12.1
21-06-04 16:27:44 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-check_config with version 3.7.1
21-06-04 16:27:45 INFO (MainThread) [supervisor.snapshots] Found 2 snapshot files
21-06-04 16:27:45 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
21-06-04 16:27:45 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-06-04 16:27:45 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-06-04 16:27:45 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-04 16:27:45 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-06-04 16:27:45 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-04 16:27:45 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-06-04 16:27:45 INFO (MainThread) [__main__] Running Supervisor
21-06-04 16:27:45 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-06-04 16:27:45 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-06-04 16:27:45 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 1 add-ons
21-06-04 16:27:45 WARNING (MainThread) [supervisor.addons.options] Option 'anonymous' does not exist in the schema for Mosquitto broker (core_mosquitto)
21-06-04 16:27:45 WARNING (SyncWorker_3) [supervisor.addons.options] Option 'anonymous' does not exist in the schema for Mosquitto broker (core_mosquitto)
21-06-04 16:27:47 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-mosquitto with version 6.0.1
21-06-04 16:27:51 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
21-06-04 16:27:52 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 5 add-ons
21-06-04 16:27:52 WARNING (SyncWorker_4) [supervisor.docker.addon] Glances running with disabled protected mode!
21-06-04 16:27:53 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/glances/armv7 with version 0.12.1
21-06-04 16:27:54 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-duckdns with version 1.12.5
21-06-04 16:27:55 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/ssh/armv7 with version 8.2.3
21-06-04 16:27:56 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-samba with version 9.5.0
21-06-04 16:27:58 ERROR (MainThread) [supervisor.api.middleware_security] Invalid token for access /network/interface/default/info
21-06-04 16:27:59 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/unifi/armv7 with version 0.23.0
21-06-04 16:28:04 INFO (MainThread) [supervisor.core] Start Home Assistant Core
21-06-04 16:28:04 INFO (SyncWorker_0) [supervisor.docker.interface] Starting homeassistant
21-06-04 16:28:05 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-06-04 16:28:22 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
21-06-04 16:28:22 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-04 16:28:31 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-06-04 16:28:54 WARNING (MainThread) [supervisor.addons.options] Option 'anonymous' does not exist in the schema for Mosquitto broker (core_mosquitto)
21-06-04 16:28:55 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-06-04 16:28:55 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 4 add-ons
21-06-04 16:28:59 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-configurator with version 5.3.1
21-06-04 16:28:59 WARNING (MainThread) [supervisor.addons.options] Unknown option 'restartdelay' for Zigbee2mqtt (7ad98f9c_zigbee2mqtt)
21-06-04 16:28:59 WARNING (MainThread) [supervisor.addons.options] Unknown option 'initialdelay' for Zigbee2mqtt (7ad98f9c_zigbee2mqtt)
21-06-04 16:28:59 WARNING (SyncWorker_7) [supervisor.addons.options] Unknown option 'restartdelay' for Zigbee2mqtt (7ad98f9c_zigbee2mqtt)
21-06-04 16:28:59 WARNING (SyncWorker_7) [supervisor.addons.options] Unknown option 'initialdelay' for Zigbee2mqtt (7ad98f9c_zigbee2mqtt)
21-06-04 16:29:01 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-armv7 with version 1.18.1-1
21-06-04 16:29:02 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on esphome/esphome-hassio-armv7 with version 1.18.0
21-06-04 16:29:04 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on sabeechen/hassio-google-drive-backup-armv7 with version 0.104.3
21-06-04 16:29:09 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-06-04 16:29:09 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-06-04 16:29:09 INFO (MainThread) [supervisor.host.info] Updating local host information
21-06-04 16:29:09 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-04 16:29:09 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-06-04 16:29:09 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-06-04 16:29:09 WARNING (MainThread) [supervisor.addons.options] Option 'anonymous' does not exist in the schema for Mosquitto broker (core_mosquitto)
21-06-04 16:29:09 WARNING (MainThread) [supervisor.addons.options] Unknown option 'restartdelay' for Zigbee2mqtt (7ad98f9c_zigbee2mqtt)
21-06-04 16:29:09 WARNING (MainThread) [supervisor.addons.options] Unknown option 'initialdelay' for Zigbee2mqtt (7ad98f9c_zigbee2mqtt)
21-06-04 16:29:09 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-04 16:29:09 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-04 16:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-06-04 16:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-06-04 16:29:10 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-04 16:29:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-06-04 16:29:12 INFO (MainThread) [supervisor.api.middleware_security] /core/info access from cebe7a76_hassio_google_drive_backup
21-06-04 16:29:12 INFO (MainThread) [supervisor.api.middleware_security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
21-06-04 16:29:12 INFO (MainThread) [supervisor.api.middleware_security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-06-04 16:29:12 INFO (MainThread) [supervisor.api.middleware_security] /snapshots/10d05ace/info access from cebe7a76_hassio_google_drive_backup
21-06-04 16:29:12 INFO (MainThread) [supervisor.api.middleware_security] /snapshots/13f07114/info access from cebe7a76_hassio_google_drive_backup
21-06-04 16:29:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-04 16:29:15 INFO (MainThread) [supervisor.host] Host information reload completed
21-06-04 16:29:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-04 16:29:18 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-06-04 16:29:18 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
