Hello
On my synology I had a problem with an upgrade
it does not work anymore with the superviosr
the home assitant is ok but I annot do any backup or restore here are my logs
23-11-15 11:50:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-11-15 11:50:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-11-15 11:50:35 WARNING (MainThread) [supervisor.resolution.evaluations.base] NetworkManager is not correctly configured (more-info: Network Manager - Home Assistant)
23-11-15 11:50:35 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: None (more-info: Operating System - Home Assistant)
23-11-15 11:50:35 WARNING (MainThread) [supervisor.resolution.evaluations.base] OS-Agent is not correctly working (more-info: OS-Agent issues - Home Assistant)
23-11-15 11:50:35 WARNING (MainThread) [supervisor.resolution.evaluations.base] Systemd-Resolved is required for DNS in Home Assistant. (more-info: Systemd-Resolved - Home Assistant)
23-11-15 11:50:35 WARNING (MainThread) [supervisor.resolution.evaluations.base] Systemd is not correctly working (more-info: Systemd - Home Assistant)
23-11-15 11:50:35 WARNING (MainThread) [supervisor.resolution.evaluations.base] Systemd journal is not working correctly or inaccessible (more-info: Systemd Journal - Home Assistant)
23-11-15 11:50:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-15 11:50:35 CRITICAL (MainThread) [supervisor.jobs] The following job conditions are ignored and will make the system unstable when they occur: {<JobCondition.HEALTHY: ‘healthy’>}
23-11-15 11:50:35 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - setup
23-11-15 11:50:35 INFO (MainThread) [main] Running Supervisor
23-11-15 11:50:35 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
23-11-15 11:50:35 INFO (MainThread) [supervisor.jobs] ‘OSManager.mark_healthy’ blocked from execution, no Home Assistant OS available
23-11-15 11:50:35 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
23-11-15 11:50:35 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-11-15 11:50:35 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.11.3
23-11-15 11:50:35 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package amd64-hassio-supervisor · GitHub with tag 2023.11.3.
23-11-15 11:51:14 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-11-15 11:51:14 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-11-15 11:51:14 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-11-15 11:51:15 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-11-15 11:51:15 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-11-15 11:51:15 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-11-15 11:51:15 INFO (MainThread) [main] Closing Supervisor
[10:51:16] WARNING: Halt Supervisor
[10:51:17] INFO: Supervisor restart after closing
s6-rc: info: service legacy-services: stopping
[10:51:17] INFO: Watchdog restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[10:51:38] INFO: Setup udev backend inside container
[10:51:38] INFO: Update udev information
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[10:51:39] INFO: Starting local supervisor watchdog…
s6-rc: info: service legacy-services successfully started
23-11-15 10:51:43 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extraction
23-11-15 10:51:43 INFO (MainThread) [main] Initializing Supervisor setup
23-11-15 11:51:43 WARNING (MainThread) [supervisor.bootstrap] Missing SUPERVISOR_MACHINE environment variable. Fallback to deprecated extraction!
23-11-15 11:51:43 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-11-15 11:51:43 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor Package amd64-hassio-supervisor · GitHub with version 2023.11.1
23-11-15 11:51:43 WARNING (SyncWorker_0) [supervisor.docker.manager] Package amd64-hassio-supervisor · GitHub not found for cleanup
23-11-15 11:51:43 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-11-15 11:51:43 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker storage driver btrfs is not supported!
23-11-15 11:51:43 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker logging driver db is not supported!
23-11-15 11:51:43 WARNING (MainThread) [supervisor.resolution.evaluations.base] The configuration of Docker is not supported (more-info: Docker Configuration - Home Assistant)
23-11-15 11:51:43 WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported job conditions settings. (more-info: Ignored job conditions - Home Assistant)
23-11-15 11:51:43 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-15 11:51:43 ERROR (MainThread) [supervisor.core] Update ‘2023.11.3’ of Supervisor ‘2023.11.1’ failed!
23-11-15 11:51:43 INFO (MainThread) [supervisor.resolution.module] Create new issue update_rollback - supervisor / None
23-11-15 11:51:43 INFO (MainThread) [main] Setting up Supervisor
23-11-15 11:51:44 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-11-15 11:51:44 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-11-15 11:51:44 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface io.hass.os: The name io.hass.os was not provided by any .service files
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface org.freedesktop.hostname1: The name org.freedesktop.hostname1 was not provided by any .service files
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface org.freedesktop.NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface org.freedesktop.resolve1: The name org.freedesktop.resolve1 was not provided by any .service files
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface org.freedesktop.timedate1: The name org.freedesktop.timedate1 was not provided by any .service files
23-11-15 11:51:44 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface org.freedesktop.UDisks2: The name org.freedesktop.UDisks2 was not provided by any .service files
23-11-15 11:51:44 INFO (MainThread) [supervisor.host.services] Updating service information
23-11-15 11:51:44 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-11-15 11:51:44 INFO (MainThread) [supervisor.jobs] ‘NetworkManager.load’ blocked from execution, host Network Manager not available
23-11-15 11:51:44 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
23-11-15 11:51:44 WARNING (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
23-11-15 11:51:44 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-11-15 11:51:44 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-11-15 11:51:45 INFO (MainThread) [supervisor.docker.interface] Attaching to Package amd64-hassio-cli · GitHub with version 2023.10.0
23-11-15 11:51:45 INFO (MainThread) [supervisor.docker.interface] Attaching to Package amd64-hassio-dns · GitHub with version 2023.06.2
23-11-15 11:51:46 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-11-15 11:51:46 INFO (MainThread) [supervisor.docker.interface] Attaching to Package amd64-hassio-audio · GitHub with version 2023.10.0
23-11-15 11:51:46 INFO (MainThread) [supervisor.docker.interface] Attaching to Package amd64-hassio-observer · GitHub with version 2023.06.0
23-11-15 11:51:47 INFO (MainThread) [supervisor.docker.interface] Attaching to Package amd64-hassio-multicast · GitHub with version 2023.06.2
23-11-15 11:51:47 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
