Does it look like SD card is dying?
[18:21:15] INFO: Starting local supervisor watchdog...
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/supervisor/supervisor/__main__.py", line 8, in <module>
from supervisor import bootstrap
File "/usr/src/supervisor/supervisor/bootstrap.py", line 9, in <module>
from .addons import AddonManager
File "/usr/src/supervisor/supervisor/addons/__init__.py", line 25, in <module>
from ..store.addon import AddonStore
File "/usr/src/supervisor/supervisor/store/__init__.py", line 21, in <module>
from .repository import Repository
File "/usr/src/supervisor/supervisor/store/repository.py", line 12, in <module>
from .git import GitRepo, GitRepoCustom, GitRepoHassIO
File "/usr/src/supervisor/supervisor/store/git.py", line 7, in <module>
import git
File "/usr/local/lib/python3.11/site-packages/git/__init__.py", line 8, in <module>
from git.exc import * # @NoMove @IgnorePep8
File "/usr/local/lib/python3.11/site-packages/git/exc.py", line 8, in <module>
from gitdb.exc import BadName # NOQA @UnusedWildImport skipcq: PYL-W0401, PYL-W0614
File "/usr/local/lib/python3.11/site-packages/gitdb/__init__.py", line 36, in <module>
from gitdb.base import *
File "/usr/local/lib/python3.11/site-packages/gitdb/base.py", line 8, in <module>
from gitdb.fun import (
File "/usr/local/lib/python3.11/site-packages/gitdb/fun.py", line 18, in <module>
File "/usr/local/lib/python3.11/site-packages/gitdb/utils/encoding.py", line 1
��|��mę/��:��#5�����}�R#Io���%�X�Ë���¥�ÇN�ٽ�I'$��x|�a9eT�D�����m���k�z�����d��1�Do��Hǔ�S���������kz+2�b����!�V���6
g&:-#D#3"�gl�b��v'��i,�3��1��;s'������0JWw�
���VnO�r�=����}7�
������o�Y�j@Ĕ"E�n��d�麼bc�p|���[���v��J@���n;~6���$�=�7�'] ,�^��j껡��E��o��QZ�~�X�R���Nϯ��O�ģ#���Ք��P�>�V0Cr#�����G~~���OV������B ��P��މ/��?
SyntaxError: (unicode error) 'utf-8' codec can't decode bytes in position 0-1: invalid continuation byte
Since I can’t start the supervisor or container, any tips how I can at least extract the backup from this?
The odd thing is it creates a new supervisor container and then that’s corrupted each time. I guess I have to somehow update the supervisor… but if it’s not running then how…
