Supervisor error, Cant do anything under settings anymore, Please Help
i dont know what happend, i came back home and want to check something in my Smarthome and the complete settings area is dead, or all what has to do with the supervisor.
when i click on addons for example i get a error message and i should check the observer
HomeAssistant Observer is working
Home Assistant observer
Supervisor:	Connected
Supported:	Supported
Healthy:	Healthy
any ideas what i can to to repair my Homeassistant?
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:120
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 17:56:06 (49 occurrences)
Last logged: 18:06:09
Failed to to call /supervisor/stats -
Failed to to call /backups -
Failed to to call /host/info -
Failed to to call /os/info -
Failed to to call /network/info -
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:263
First occurred: 17:51:24 (34 occurrences)
Last logged: 17:58:31
Timeout on /os/info request
Timeout on /store request
Timeout on /supervisor/info request
Timeout on /core/info request
Timeout on /addons/3a26b21d_eufy_security_addon/info request
Source: components/hassio/__init__.py:643
First occurred: 17:52:32 (2 occurrences)
Last logged: 17:57:43
Can't read Supervisor data:
Logger: hass_nabucasa.iot
Source: /usr/local/lib/python3.9/site-packages/hass_nabucasa/iot_base.py:264
First occurred: 17:57:19 (2 occurrences)
Last logged: 17:57:38
Unable to connect: 504, message='Invalid response status', url=URL('wss://cloud.nabucasa.com/websocket')
Logger: custom_components.openmediavault.omv_api
Source: custom_components/openmediavault/omv_api.py:301
Integration: OpenMediaVault (documentation, issues)
First occurred: 17:51:36 (2 occurrences)
Last logged: 17:57:36
OpenMediaVault 192.168.0.53 unable to fetch data (401)
Logger: homeassistant.config_entries
Source: custom_components/eufy_security/__init__.py:80
Integration: Eufy Security (documentation, issues)
First occurred: 17:55:27 (1 occurrences)
Last logged: 17:55:27
Error unloading entry localhost for eufy_security
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 478, in async_unload
    result = await component.async_unload_entry(hass, self)
  File "/config/custom_components/eufy_security/__init__.py", line 80, in async_unload_entry
    coordinator.update_listener()
TypeError: 'NoneType' object is not callable
Unfortunately, its an issue reported by more users, but no valuable fix apart from restarting core… Cant read supervisor data - #4 by fraintt
