Hi there
Tried searching for this but couldn’t find a reference, I have this error message every 2 minutes in my logs, can’t find what’s triggering it (the Task ID changes every time):
21-06-01 00:23:15 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1686972' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=TypeError('an integer is required (got type str)')>
File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task
await task.coro_callback()
File "/usr/src/supervisor/supervisor/misc/tasks.py", line 416, in _watchdog_addon_application
if addon.in_progress or await addon.watchdog_application():
File "/usr/src/supervisor/supervisor/addons/addon.py", line 479, in watchdog_application
return await self.sys_run_in_executor(check_port, self.ip_address, port)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/supervisor/supervisor/utils/__init__.py", line 43, in check_port
result = sock.connect_ex((str(address), port))
TypeError: an integer is required (got type str)
Any ideas?
TIA
