I’m trying to access the /api/hassio/backups/ endpoint.
It looks like I can only get access using the Supervisor token if I am coming from within the Docker network and accessing 172.30.232.2
Without adding socat somewhere, how can I get Supervisor access?
I question the value of having a REST API that is so limited. I understand the push to create addons but I want to integrate Home Assistant with the rest of my network, not the other way around.
The Supervisor really is mostly about providing infrastructure to support Home Assistant Core. The API’s main users are the Core and the Add-ons today. What is your use case to control it from outside?
I have created a bit of a Rube Goldberg backup system, but accessing the /backup endpoint is good because I can run a script on another system that downloads all existing backup tar files and then removes the ones I’ve got backed up separately.
I also want to enable automatic updating of OS components and addons, but I’ll try one of the blueprints for that first.
