Hi guys,
After updating to 11.0 I am receiving a Supervisor error " failed to setup"
It seems all is still working flawlessly, all addon is ok.
Is there anyone who can figure out what is happening
Thank you
This is the supervisor log
File "/usr/local/lib/python3.11/site-packages/git/remote.py", line 1014, in fetch
res = self._get_fetch_info_from_stderr(proc, progress, kill_after_timeout=kill_after_timeout)
File "/usr/local/lib/python3.11/site-packages/git/remote.py", line 853, in _get_fetch_info_from_stderr
proc.wait(stderr=stderr_text)
File "/usr/local/lib/python3.11/site-packages/git/cmd.py", line 602, in wait
raise GitCommandError(remove_password_if_present(self.args), status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
cmdline: git fetch -v --update-shallow --depth=1 -- origin
stderr: 'fatal: unable to access 'https://github.com/home-assistant/addons/': Failure when receiving data from the peer'
File "/usr/src/supervisor/supervisor/store/repository.py", line 108, in update
await self.git.pull()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 281, in wrapper
raise err
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 274, in wrapper
return await self._method(obj, *args, **kwargs)
File "/usr/src/supervisor/supervisor/store/git.py", line 178, in pull
raise StoreGitError() from err
supervisor.exceptions.StoreGitError
23-10-14 06:51:30 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 06:51:30 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 06:51:31 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 06:51:31 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 06:52:20 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqttuser'
23-10-14 06:52:20 INFO (MainThread) [supervisor.auth] Successful login for 'mqttuser'
23-10-14 06:53:31 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 06:55:31 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 06:55:31 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 06:55:32 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 06:55:32 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 06:57:21 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqttuser'
23-10-14 06:57:21 INFO (MainThread) [supervisor.auth] Successful login for 'mqttuser'
23-10-14 06:57:32 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 06:59:32 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 06:59:32 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 06:59:33 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 06:59:33 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:01:33 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:03:33 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:03:33 INFO (SyncWorker_5) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:03:33 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:03:34 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:05:34 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:06:39 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqttuser'
23-10-14 07:06:39 INFO (MainThread) [supervisor.auth] Successful login for 'mqttuser'
23-10-14 07:07:34 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:07:34 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:07:34 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:07:35 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:08:28 INFO (MainThread) [supervisor.host.info] Updating local host information
23-10-14 07:08:29 INFO (MainThread) [supervisor.host.services] Updating service information
23-10-14 07:08:29 INFO (MainThread) [supervisor.host.network] Updating local network information
23-10-14 07:08:29 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-10-14 07:08:29 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-10-14 07:09:35 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:11:35 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:11:35 INFO (SyncWorker_7) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:11:35 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:11:35 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:13:35 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:15:35 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:15:35 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:15:36 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:15:36 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:15:43 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-10-14 07:15:48 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqttuser'
23-10-14 07:15:49 INFO (MainThread) [supervisor.auth] Successful login for 'mqttuser'
23-10-14 07:17:36 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:19:36 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:19:36 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:19:37 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:19:37 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:21:37 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:23:37 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:23:37 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:23:38 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:23:38 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:24:57 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqttuser'
23-10-14 07:24:58 INFO (MainThread) [supervisor.auth] Successful login for 'mqttuser'
23-10-14 07:25:38 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
23-10-14 07:27:38 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 6bfc5972_hasspyfrigate application!
23-10-14 07:27:38 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping addon_6bfc5972_hasspyfrigate application
23-10-14 07:27:38 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_6bfc5972_hasspyfrigate application
23-10-14 07:27:39 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 6bfc5972/amd64-addon-hasspyfrigate with version 0.1
23-10-14 07:29:39 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from 6bfc5972_hasspyfrigate
this is the error in core
Logger: homeassistant.config_entries
Source: config_entries.py:399
First occurred: 09:53:04 (1 occurrences)
Last logged: 09:53:04
Error setting up entry Supervisor for hassio
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 399, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 670, in async_setup_entry
await coordinator.async_config_entry_first_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 255, in async_config_entry_first_refresh
await self._async_refresh(
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 979, in _async_refresh
await self.hassio.refresh_updates()
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 37, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 561, in send_command
request = await self.websession.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
asyncio.exceptions.CancelledError: Global task timeout
