I had to reinstall Home Assistant Supervised because I was having problems with it starting. I deleted all the docker containers and reran the install script. I realized that most configurations were still there after reinstalling. I have two devices connected so far, both via zigbee2mqtt. I realized that the device switches were not reacting anymore on Lovelace, so I deleted them. I thought they would automatically reappear after reconnecting them with zigbee2mqtt, but they are gone. I then deleted one entitiy in Mosquitto and it is also not reappearing. I then tried to gain control over Lovelace to add the remaining entity manually, which also did not work.
How can I let the supervisor regain control of Lovelace and add entities automatically again?
I also tried installing the Simple Scheduler and it is also not showing any devices. I guess for the same reason.
I would also not have a problem with a clean start, as I only have two devices connected so far. I already stopped the hassio-supervisor and hassio-apparmor services and deleted all the docker containers last time. Most configurations were still there. What would I have to do to wipe Home Assistant completely and start from scratch?
Here is my supervisor log
1-08-02 18:25:53 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-08-02 18:25:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-08-02 18:25:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-08-02 18:25:53 INFO (MainThread) [__main__] Running Supervisor
21-08-02 18:25:53 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
21-08-02 18:25:53 INFO (MainThread) [supervisor.jobs] 'HassOS.mark_healthy' blocked from execution, no Home Assistant OS available
21-08-02 18:25:53 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-08-02 18:25:53 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 1 add-ons
21-08-02 18:25:53 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
21-08-02 18:25:59 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-mosquitto with version 6.0.1
21-08-02 18:26:03 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
21-08-02 18:26:04 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 1 add-ons
21-08-02 18:26:04 ERROR (MainThread) [supervisor.addons.addon] Add-on core_duckdns has invalid options: Missing required option 'token' in Duck DNS (core_duckdns). Got {'lets_encrypt': {'accept_terms': False, 'certfile': 'fullchain.pem', 'keyfile': 'privkey.pem'}, 'token': None, 'domains': [None], 'aliases': [], 'seconds': 300}
21-08-02 18:26:04 WARNING (MainThread) [supervisor.addons] Can't start Add-on core_duckdns
21-08-02 18:26:09 INFO (MainThread) [supervisor.core] Start Home Assistant Core
21-08-02 18:26:09 INFO (SyncWorker_3) [supervisor.docker.interface] Starting homeassistant
21-08-02 18:26:11 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-08-02 18:26:42 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
21-08-02 18:26:42 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-08-02 18:27:00 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
21-08-02 18:27:00 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-08-02 18:27:01 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
21-08-02 18:27:06 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-08-02 18:27:06 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 2 add-ons
21-08-02 18:27:07 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_45df7312_zigbee2mqtt application
21-08-02 18:27:14 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-armv7 with version 1.21.0-1
21-08-02 18:27:15 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_00185a40_simplescheduler application
21-08-02 18:27:22 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on 00185a40/armv7-addon-simplescheduler with version 0.30.05
21-08-02 18:27:24 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.1:8099 ssl:default [Connect call failed ('172.30.33.1', 8099)]
21-08-02 18:27:27 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-08-02 18:27:27 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-08-02 18:27:27 INFO (MainThread) [supervisor.host.info] Updating local host information
21-08-02 18:27:27 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_SNAPSHOT - ContextType.SYSTEM / None
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-08-02 18:27:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-08-02 18:27:28 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.1:8099 ssl:default [Connect call failed ('172.30.33.1', 8099)]
21-08-02 18:27:28 INFO (MainThread) [supervisor.host.services] Updating service information
21-08-02 18:27:28 INFO (MainThread) [supervisor.host.network] Updating local network information
21-08-02 18:27:29 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-08-02 18:27:29 INFO (MainThread) [supervisor.host] Host information reload completed
21-08-02 18:27:37 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-08-02 18:27:37 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-08-02 18:27:37 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-08-02 18:28:09 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.1:8099 ssl:default [Connect call failed ('172.30.33.1', 8099)]
21-08-02 18:28:14 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.1:8099 ssl:default [Connect call failed ('172.30.33.1', 8099)]
21-08-02 18:28:15 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt_user'
21-08-02 18:28:16 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt_user'
21-08-02 18:33:09 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
21-08-02 18:33:10 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
21-08-02 18:39:10 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
21-08-02 18:39:10 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
21-08-02 18:42:26 INFO (SyncWorker_2) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/raspberrypi4-homeassistant
21-08-02 18:42:33 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-08-02 18:42:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-08-02 18:42:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-08-02 18:42:48 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-08-02 18:43:05 INFO (SyncWorker_2) [supervisor.docker.interface] Stopping addon_45df7312_zigbee2mqtt application
21-08-02 18:43:08 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_45df7312_zigbee2mqtt application
21-08-02 18:43:08 INFO (SyncWorker_2) [supervisor.docker.interface] Removing image zigbee2mqtt/zigbee2mqtt-armv7 with latest and 1.21.0-1
21-08-02 18:43:10 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/45df7312_zigbee2mqtt
21-08-02 18:43:10 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for 45df7312_zigbee2mqtt
21-08-02 18:43:10 INFO (MainThread) [supervisor.addons] Add-on '45df7312_zigbee2mqtt' successfully removed
21-08-02 18:43:20 INFO (SyncWorker_1) [supervisor.docker.interface] Stopping addon_core_mosquitto application
21-08-02 18:43:23 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
21-08-02 18:43:23 INFO (SyncWorker_1) [supervisor.docker.interface] Removing image homeassistant/armv7-addon-mosquitto with latest and 6.0.1
21-08-02 18:43:23 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/core_mosquitto
21-08-02 18:43:23 INFO (MainThread) [supervisor.discovery] Delete discovery to Home Assistant mqtt from core_mosquitto
21-08-02 18:43:23 INFO (MainThread) [supervisor.addons] Add-on 'core_mosquitto' successfully removed
21-08-02 18:43:24 INFO (MainThread) [supervisor.discovery] Discovery 032dbbd814dd42e4a41be6935aed2c48 message send
21-08-02 18:43:27 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/core_mosquitto
21-08-02 18:43:27 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/armv7-addon-mosquitto with tag 6.0.1.
21-08-02 18:43:36 INFO (MainThread) [supervisor.addons] Add-on 'core_mosquitto' successfully installed
21-08-02 18:43:45 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/armv7-addon-mosquitto with version 6.0.1
21-08-02 18:43:47 INFO (MainThread) [supervisor.discovery] Sending discovery to Home Assistant mqtt from core_mosquitto
21-08-02 18:43:47 INFO (MainThread) [supervisor.discovery] Discovery f9130834d31a4dc880e513785ec6c017 message send
21-08-02 18:43:47 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
21-08-02 18:43:51 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/45df7312_zigbee2mqtt
21-08-02 18:43:51 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image zigbee2mqtt/zigbee2mqtt-armv7 with tag 1.21.0-1.
21-08-02 18:44:18 INFO (MainThread) [supervisor.addons] Add-on '45df7312_zigbee2mqtt' successfully installed
21-08-02 18:44:22 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for 45df7312_zigbee2mqtt
21-08-02 18:44:29 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-armv7 with version 1.21.0-1
21-08-02 18:44:49 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
21-08-02 18:44:49 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
21-08-02 18:46:03 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-08-02 18:46:03 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-08-02 18:46:03 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-08-02 18:49:14 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-08-02 18:50:49 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
21-08-02 18:50:50 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
