Why does Supervisord keep going into an “unhealthy” state on my system? Dropping out from being privileged?
This didn’t use to be a problem, but now it seems any time I do anything on my system, HA Supervisor goes into an “unhealthy” state. It was just fine yesterday. However, now it’s “unhealthy” and the only thing I did was update my plex package (apt update -y).
The message is “Supervisor is not privileged” which doesn’t make sense. How does it drop out from being privileged?
OS: Ubuntu 20.04.2
My solution has been “reboot” and Supervisor is back to normal. That would mean settings are fine.
David I have nothing but respect for Debian but you are missing the point so let me explain…
Just because I like trimming my rose garden over the weekend does not imply that I aspire to be a gardener. All of this home automation stuff is just a vocation for me, so I have no problem starting fresh or taking alternate route. But I really like the LTS part of Ubuntu and I think at some point in time HA will have to make its peace with whatever is more popular distro at that time.
You are deluding yourself. This is not going to change to what you want. If you don’t want to accept that then that’s your choice but reality is likely to bite and soon. Ubuntu is already causing grief and I wouldn’t expect that to change.
Same here. I cursed and moaned about it. After all Ubuntu is such s popular os.
Then I got in with it, it took a few hours, and debian works much better and is vastly lighter on resources
I am planning to put a rack sever (with no UI and only ssh access) in attic that will run HA amongst many other things such as Zoneminder, log server, NAS.
How would you care to guess the switch/learning curve from Ubuntu to Debian? Just need some pointer and at the end of the day its my call but thanks for chipping in on the subject
The drop out to is caused by auto update of supervisor. Every time it updates, it checks the system and gives “unhealthy-priviliged” error. I keep up with:
sudo docker restart hassio_supervisor
and you don’t need to restart HA; it corrects the error itself.
Almost no learning curve needed.
Ubuntu is based on Debian.
The only issue I had is I use the same box as a Plex server with a media HDD, in Ubuntu i could just tick a box to shut the drive down automatically if it wasn’t in use. In Debian I had to put a script in place to set this on startup. Pretty easy though.
I run the version of Debian with no GUI.
I installed webmin which gives me a web interface for doing updates etc, when they are needed (usually monthly).
As for the rack in the attic. Does your attic get hot in the summer?
Thanks, really liked the tips and have used Webmin and its pretty cool!
The attic gets hot which is a relative term but yes about 80F in winters and 110 F in Summers but it is covered with insulation, is there a reason you asked?
Solid state drives make such a difference.
The only spinning drive I have left is that media one.
It only spins while I’m watching a movie on Plex, maybe once a week.
