Supervisor not connected
Hi everyone,
my hassio is acting up and currently supervisor is not responding, which means none of my addons are running.
The observer logs state multuple times that supervisor is shutting down because the API could not be reached (ERROR: Something went wrong contacting the API). I have no idea what that means or why it is occurring… I have manually checked the available disk size and it has enough free space. I noticed there were a few “corrupt” db entries, but that is another issue…
Hardware: Raspi 3b
Observer log:
Supervisor: 	Disconnected
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:37:03] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[17:37:04] INFO: Starting local supervisor watchdog...
2026-01-22 17:37:15.681 INFO (MainThread) [__main__] Initializing Supervisor setup
2026-01-22 17:37:16.116 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: raspberrypi3-64
2026-01-22 18:37:16.155 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2026.01.1
2026-01-22 18:37:16.252 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2026-01-22 18:37:16.263 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-01-22 18:37:16.266 INFO (MainThread) [__main__] Setting up Supervisor
2026-01-22 18:37:16.584 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2026-01-22 18:37:16.939 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2026-01-22 18:37:16.946 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2026-01-22 18:37:16.949 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2026-01-22 18:37:16.952 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2026-01-22 18:37:16.954 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2026-01-22 18:37:16.956 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2026-01-22 18:37:17.958 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2026-01-22 18:37:17.959 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2026-01-22 18:37:17.960 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2026-01-22 18:37:17.961 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2026-01-22 18:37:18.198 INFO (MainThread) [supervisor.host.services] Updating service information
2026-01-22 18:37:18.225 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2026-01-22 18:37:18.243 WARNING (SyncWorker_4) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2026-01-22 18:37:19.057 INFO (MainThread) [supervisor.host.network] Updating local network information
2026-01-22 18:37:19.369 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2026-01-22 18:37:19.549 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 17.0 / BootSlot A
2026-01-22 18:37:19.564 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2026-01-22 18:37:19.583 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2026.01.0
2026-01-22 18:37:19.814 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2026-01-22 18:37:19.841 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_cli application
2026-01-22 18:37:23.105 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2026.01.0 - 172.30.32.5
2026-01-22 18:37:23.199 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2025.08.0
2026-01-22 18:37:23.650 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2026-01-22 18:37:23.675 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_dns application
2026-01-22 18:37:28.369 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2025.08.0 - 172.30.32.3
2026-01-22 18:37:28.376 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2026-01-22 18:37:28.417 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2025.08.0
2026-01-22 18:37:28.465 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2026-01-22 18:37:28.525 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
2026-01-22 18:37:35.640 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2025.08.0 - 172.30.32.4
2026-01-22 18:37:35.660 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0
2026-01-22 18:37:35.909 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2025.08.0
2026-01-22 18:37:36.113 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2026-01-22 18:37:36.156 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning hassio_multicast application
2026-01-22 18:37:43.269 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2025.08.0 - Host
2026-01-22 18:37:43.316 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version 2025.8.3
2026-01-22 18:37:43.324 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2026-01-22 18:37:43.627 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2026-01-22 18:37:43.652 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2026-01-22 18:37:43.666 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2026-01-22 18:37:43.667 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2026-01-22 18:37:43.674 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/1376549a repository
2026-01-22 18:37:57.204 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Log Viewer' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:57.224 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'MQTT IO' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:57.248 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Tailscale' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:57.273 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Grocy' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:57.283 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Overseerr' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:57.413 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'InfluxDB' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:57.431 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Folding@home' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:37:58.239 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Glances' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:38:00.852 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Traccar' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:38:00.974 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on 'Nginx Proxy Manager' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-22 18:38:01.050 INFO (MainThread) [supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
2026-01-22 18:38:01.214 INFO (MainThread) [supervisor.addons.manager] Found 2 installed add-ons
2026-01-22 18:38:01.335 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0
2026-01-22 18:38:01.343 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 6.5.1
2026-01-22 18:38:01.568 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
2026-01-22 18:38:01.578 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2026-01-22 18:38:01.578 INFO (MainThread) [supervisor.ingress] Loaded 3 ingress sessions
2026-01-22 18:38:01.579 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2026-01-22 18:38:01.579 INFO (MainThread) [supervisor.resolution.checks.base] Run check for deprecated_addon/addon
2026-01-22 18:38:01.579 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2026-01-22 18:38:01.580 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2026-01-22 18:38:01.580 INFO (MainThread) [supervisor.resolution.checks.base] Run check for duplicate_os_installation/system
2026-01-22 18:38:01.763 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2026-01-22 18:38:01.764 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2026-01-22 18:38:01.764 INFO (MainThread) [supervisor.resolution.check] System checks complete
2026-01-22 18:38:01.765 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2026-01-22 18:38:01.768 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-01-22 18:38:01.769 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2026-01-22 18:38:01.857 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2026-01-22 18:38:01.931 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2026-01-22 18:38:02.070 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2026-01-22 18:38:02.098 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 1 add-ons
2026-01-22 18:38:02.224 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_core_mosquitto application
2026-01-22 18:38:05.944 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.5.1
2026-01-22 18:38:10.957 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2026-01-22 18:38:10.976 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2026-01-22 18:38:11.095 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
2026-01-22 18:38:12.823 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2026-01-22 18:38:36.703 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
2026-01-22 18:38:52.653 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2026-01-22 18:38:52.655 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-01-22 18:38:53.116 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2026-01-22 18:38:53.133 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2026-01-22 18:39:05.045 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'marstek'
2026-01-22 18:39:05.070 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
2026-01-22 18:39:54.812 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2026-01-22 18:39:54.813 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2026-01-22 18:39:54.841 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 1 add-ons
2026-01-22 18:39:55.336 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_configurator application
2026-01-22 18:40:04.163 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.8.0
2026-01-22 18:40:35.777 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2026-01-22 18:40:35.780 INFO (MainThread) [supervisor.host.info] Updating local host information
2026-01-22 18:40:35.819 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2026-01-22 18:40:35.824 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2026-01-22 18:40:35.833 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2026-01-22 18:40:35.887 INFO (MainThread) [supervisor.core] Supervisor is up and running
2026-01-22 18:40:35.889 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2026-01-22 18:40:35.909 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2026-01-22 18:40:35.916 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2026-01-22 18:40:36.051 INFO (MainThread) [__main__] Running Supervisor
2026-01-22 18:40:36.084 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2026-01-22 18:40:36.282 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2026-01-22 18:40:36.288 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2026-01-22 18:40:36.293 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2026-01-22 18:40:36.297 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2026-01-22 18:40:36.313 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2026-01-22 18:40:36.317 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disk_lifetime/system
2026-01-22 18:40:36.347 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2026-01-22 18:40:36.353 INFO (MainThread) [supervisor.resolution.check] System checks complete
2026-01-22 18:40:36.354 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2026-01-22 18:40:37.124 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-01-22 18:40:37.127 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2026-01-22 18:40:37.129 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2026-01-22 18:40:38.756 INFO (MainThread) [supervisor.host.services] Updating service information
2026-01-22 18:40:38.793 INFO (MainThread) [supervisor.host.network] Updating local network information
2026-01-22 18:40:40.772 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2026-01-22 18:40:41.028 INFO (MainThread) [supervisor.host.manager] Host information reload completed
[17:42:38] ERROR: Something went wrong contacting the API
[17:42:38] WARNING: Maybe found an issue on API healthy
[17:42:41] WARNING: Halt Supervisor (Wuff)
[17:42:41] INFO: Watchdog restart after closing
s6-rc: info: service legacy-services: stopping
2026-01-22 18:42:41.563 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
2026-01-22 18:42:41.573 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
2026-01-22 18:42:41.574 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
2026-01-22 18:42:41.600 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
2026-01-22 18:42:41.642 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
2026-01-22 18:42:41.702 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
2026-01-22 18:42:41.771 INFO (MainThread) [supervisor.core] Supervisor is down - 0
2026-01-22 18:42:41.803 INFO (MainThread) [__main__] Closing Supervisor
[17:42:44] WARNING: Halt Supervisor
(I cut the restarting bits because of the size limitation and also because the error stays the same)
Does anybody have any idea what I can do to fix it?
Does no one have any idea?
Probably network configuration errors if it is a connectivity issue.
Pi 3b, no memory size mentioned, tailscale, pulseaudio, DNS, multicast, deprecated warnings, loys of add-ons, limited error log - a bit of scrambled eggs to unwind.
Mantra: DNS, Its always DNS!
I mean maybe… but it does not state which API and I can reach the server without issues…I only have zigbee devices and the mqtt broker mosquitto. Nothing else… How would I check whether I can reach the API?
